http://www.stromtrooper.com/informa...stment-poll-those-who-have-done-had-done.htmlIs there anybody out there that NEEDED an adjustment at 15K?
At roughly 15K on the odo my valves were dead center spec. I had the mechanic open them up to the widest spec. I anticipate having to worry about valves when I have to worry about what junkyard to haul the bike to.Even if the clearance is in spec but at the tight end, adjusting to the mid point or slightly wider clearance will probably mean that the valves not need an adjustment for many, many more miles. Set 'em and forget 'em.
I wound up doing more work avoiding the inevitable. Over three clearance checks, two valves were hanging on the edge of the minimum. On the third check, I got them all between half and maximum and intend to stop checking. Before anybody asks about why the between half and maximum, the difference between shims is .05mm and the difference between half and maximum is also .05mm. Unless the original gap is right at full or middle, between is where it winds up.Even if the clearance is in spec but at the tight end, adjusting to the mid point or slightly wider clearance will probably mean that the valves not need an adjustment for many, many more miles. Set 'em and forget 'em.
you may not have to adjust the valves, but you only know if your check themThe title says it. Don't want to go to the difficulty of chking valve clearance if it's not needed. What do you think?
Wow! Very complete. Convinces me that I'll want the dealer to complete this work.2007 DL-650 Valve Check and Adjustment « Black Lab Adventures
This link/article by Black Lab has everything you need to check your valves by yourself.
