1 - 4 of 4 Posts
Does anyone know where to locate the fuse for the 12V cigarette lighter outlet?
I'm pretty sure I blew mine while plugging in a small tire inflator to it.
It doesn't seem to be on the main fuse cluster.
It's listed as fuse #1 in the wiring diagram. It's a 3A fuse and the power socket is for charging a phone or GPS, very light duty.
In the fuse box, left front corner, P-Source, 3 amp. Don't put in a higher amp fuse. You'd risk melting the wires or the outlet.
https://www.bluesea.com/products/1011/12_Volt_Dash_Socket
I think the rectangular bezel can be removed.
I've been planning on putting in a 15 amp marine power outlet...haven't yet picked the spot.
phatguy in Cbus
Mounted my 15 amp PowerLet socket inside the triangle made by the left rear passenger foot peg mount. Works great for Slime air pump or my heated vest.
I use a 90 deg male plug for a low profile connection and an SAE opposite end connector . It's wired directly to the battery (fused of course) so it also doubles as the battery charger input.
1 - 4 of 4 Posts
