I hit 10k today on my rear tire
in general, the CT performs very similar to a MC tire
I'm still searching for the desired pressure, too high and it increases countersteer effort, too low and you have wallowing with sidewall flexing
I started at 41psi, went up to 45psi then down to 32psi then down to 25psi, I'm back up to 33psi planning on putting it up to 37 for the next thousand miles or so
the CT amplifies imperfections in handling, also the larger contact patch feels more road imperfections
tread depth in the center is 8-9mm and at the edges 9-10mm
