1 - 4 of 4 Posts
Howdy V experts..
It's sunny today in the mountains of Idaho (still have several feet of snow on ground), so I decided to resume troubleshooting my 07 V.
Last (late) fall I had a charging issue, so I replaced the stator and did the jb weld fix for 4 floating magnets. Bike would start & run on fresh charged battery prior to replacement, but would not charge.
So I decided to check the error code (never needed to do this since buying bike last summer), but.. I have dug, and dug but cannot find
the dealer mode plug. -- Any ideas?
I suspect the crank position sensor (?)
Try YouTube--it shows a DL650, I dont know if your 1000 is the same. The videol(link woudnt open on this site) shows it adjacent to the battery on a bracket, white 6-pole connector with a black rubber cap.
I found the dealer plug
Thank you for the replies...
I finally found the plug.. it was rear of the R/R about 8-9" along the frame tucked up under the wiring harness...
-C-12....
1 - 4 of 4 Posts
