Can anyone tell me how much of theses two bikes are identical outside of the engine.
and here we go
They use the same main frame casting but different steel rear subframes. The 650 has a slightly longer wheelbase due to a longer swingarm.
The Vee has
A cartridge fork, allowing separate compression and rebound damping settings, though not a well set up example of one
Rubber mounted handlebars
A hydraulically activated clutch
A tendency to get clutch chudder with basket wear
Not as good a fuel map
A chain adjustment system that has the adjuster welded to the swingarm and a few have had that weld crack
A slightly longer shock with the gas and oil separated by a piston
A possible sprocket alignment problem that may wear rear sprocket carrier cush rubbers out earlier
More power
A scissor gear camshaft drive that makes valve shims easier to replace but also a rare possibility of gear breakage
User adjustable idle speed in all years
Dual exhausts
The Wee has
A simple, cheap damper rod fork, requiring the same compression and rebound damping settings
Solid mounted handlebars
A cable actuated clutch
A chain adjustment system that has the adjuster held in the swingarm by the axle and adjuster bolt
A slightly shorter shock with the gas and oil mixed in one chamber
Less power
A direct chain camshaft drive that makes valve shims significantly harder to replace
User adjustable idle speed 2004-2006 but computer controlled idle speed from 2007 on
2 into 1 exhaust
ABS available as an option beginning in 2007 but mandatory in later models with the year dependent on the country
You are a good man Pat, I would of course just say "search/browse the forum or Google is your friend". ;)
