PC8 Install - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 1 Old 03-31-2013, 06:11 PM Thread Starter
flyingjib's Avatar
Thumbs up PC8 Install
So, I've had this Eastern Beaver fuse block hanging around since winter. With the fine weather it's time to get crackin' and farkle up the Wee. I checked out Jim's installation instructions on the EB site but didn't like how the fuse block sat in the seat pan. Instead, I decided to fabricate a metal shelf to hold the FB level in the tray. Luckily I had a piece of galvanized steel of adequate thickness handy so cut and bent it to this shape:
As you can see the FB was bolted to the shelf prior to the install. Yes, thread lock was used. I then offered up the shelf, marked and drilled holes and bolted the sucker in place. Again, blue 'Loctite' was used :
Once bolted in place I wired it up pretty much as per Jim's site instructions. I zip tied the relay to the outside of the tray and cut an access for the main wiring. To get the wiring to lay up proper I had to install the relay above an existing connector but figure I can just cut the zip tie if I have to access that. This is pretty well what it looked like:
And here:
Finally, I had to track down the connector for the rear lights to hook up the FB relay to. It's right where everyone said, under the fuel tank. So, I popped that up and found the connector. At least I think it's the correct one, the only two pin one under the tank. We shall see when I test everything. Here's a couple of pics of the connector:
A bit hard to see but you get the idea. This install is part of my spring upgrade programme which includes upgrading the stock front brakes with a set of Nissin 4 pot units from a CBR 600 RR and all the goodies from Blair at SV Racing. Also have a set of ProTaper bars to install and a neat pair of LED driving lights and a set of Happy Trail panniers and racks. Lots to do, I'll keep you posted.
Earl
2006 Red Wee Strom
1984 Honda VT500FT Ascot
flyingjib is offline
