Zumo 660 won't connect to PC via USB - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By CanadianFZ6
  • 1 Post By mtnbiker
post #1 of 10 Old 03-26-2013, 08:09 AM Thread Starter
V-BONG's Avatar
Has anyone had a problem connecting your 660 to a PC? I attached the car cradle and at the back is a USB port. When I plug the USB wire and plug to the PC the unit will pop a message saying "The USB cable is connected to the wrong port". Any fixes/help or suggestions is appreciated...thanks
V-BONG is offline
post #2 of 10 Old 03-26-2013, 08:14 AM
CanadianFZ6's Avatar
Have you re-booted your computer? Can you just use a (the) USB cable directly to you PC sans cradle?
Sgt Schultz likes this.
2015 DL650AL5 in Blue
CanadianFZ6 is offline
post #3 of 10 Old 03-26-2013, 08:17 AM
mtnbiker's Avatar
I connect mine using the cable that came with the unit that is USB at one end and mini USB at the other. You need to remove the battery cover to plug in the mini USB connector. This is what is shown in the Garmin user manual.
2006 DL1000
mtnbiker is offline
post #4 of 10 Old 03-26-2013, 08:18 AM
I believe that port is for the traffic receiver. You can only use the one behind the battery door for actual data transfers.
Mellow is offline
post #5 of 10 Old 03-26-2013, 09:02 AM
Garbage Marc's Avatar
Re: Zumo 660 won't connect to PC via USB
+1 the correct port is behind the battery door.
Sent from my DROID RAZR using Motorcycle.com App
" Do not argue with an idiot. He will drag you down to his level and beat you with experience."
Present Rides
[*]2015 KTM 1290 SA[*]2012 Road Glide Ultra[*]2013 KTM 500 EXC
Garbage Marc is offline
post #6 of 10 Old 03-26-2013, 12:35 PM Thread Starter
V-BONG's Avatar
I am a little bit surprised by Garmins design having to open the Battery door every time I would sync my unit to my PC. I think it's just impractical. Nevertheless I have to live with. Thanks a lot for your response...
One more thing...where did you run your cradle hard wire on your Vstrom..I have the SW Motech anti vibration mounts and I can't seem to find a way to run the Garmin wires which is quite thick in diameter. I hate to drill a hole on my bike...any idea?
V-BONG is offline
post #7 of 10 Old 03-26-2013, 12:46 PM
Cutting the wire and making a hole in one of the rubber inserts in an unused windscreen mounting hoke works fine. Then connect the wires back together.
post #8 of 10 Old 03-27-2013, 10:25 AM
janiceclanfield's Avatar
Probably trouble with the F4U tube. Check the filament.
janiceclanfield is offline
post #9 of 10 Old 01-05-2016, 10:50 PM
I plugged the Garmin-supplied USB-miniUSB cable into a USB port on my PC and into the miniUSB port inside the battery door. All I get is a message saying to close the battery door.
No PC-GPS image appears on the device.
rkondivers is offline
post #10 of 10 Old 01-05-2016, 11:28 PM
What model Garmin is it?
