wiring plan look OK ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 02-17-2013, 12:36 AM Thread Starter
In this diagram I am using the ground from the grip heater accessory plug behind the radiator for ground to: relay -, heat grips and HID.
Should I use a bigger guage wire and do a ground run to the battery for the HID instead?
Valkyrie 2000 x '03 750lbs + Farkles
DL650 2004 x 2011 approaching Valk in weight with all the "improvements"
Cogito Ergo Sum (Rene Descartes 1637 )
Reciproca non est verum (Frank and Ernie 2013)
(I think, therefore I am. The reverse is not true)
Hondasan is offline
post #2 of 5 Old 02-17-2013, 12:48 AM
I can't see the pic well enough but, from the description, I'd say that is more than I'd like the heated grip connector ground wire to handle.
post #3 of 5 Old 02-17-2013, 01:21 AM Thread Starter
so best home run ground for relay/HID and
and just use the grip plug + for the a switched source for the relay trigger/+ for heated grips sound OK ?
I have the bike apart, tank of Etc so easy to run wires- trying to keep it as compact as I can though
Hondasan is offline
post #4 of 5 Old 02-17-2013, 01:56 AM
That's good. Just use the orange/green wire as a relay trigger wire.
post #5 of 5 Old 02-17-2013, 02:05 AM Thread Starter
thanks !
I appreciate your expertise
Hondasan is offline
