installed warm'n safe.....not sure if this is right - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 09-17-2012, 10:46 PM Thread Starter
toronto_nic's Avatar
so I got my stuff installed, pretty easy. i have the 65watt jacket + gloves.
go the controller synched up.
so, a few questions:
-how long should the jacket take to warm up? after 10 minutes im getting some heat
-should it be warm everywhere? its feeling kinda spotty at best right now. mostly warm in hte front, not much on the back
2008 Vstrom DL 1000
toronto_nic is offline
post #2 of 11 Old 09-17-2012, 10:49 PM
Oofda, Dude, my Gerbing be hot right now. You have a electrical problem. The heat should flow almost instantly.
I found that a dual controller made the jacket and gloves work independently. A single controller put the heat in the gloves and not the jacket. Something is incompatible.
post #3 of 11 Old 09-17-2012, 11:41 PM
You should feel heat in a matter of seconds. What are you using for a controller? How is it wired?
post #4 of 11 Old 09-17-2012, 11:50 PM Thread Starter
using the dual wireless.
2008 Vstrom DL 1000
post #5 of 11 Old 09-17-2012, 11:53 PM
I take it the gloves are working okay. If so, swap the glove and jacket connections to the controller and see if there is a difference.
post #6 of 11 Old 09-18-2012, 09:08 AM Thread Starter
can I test this via my battery charger or do i need to be on the bike/battery?
2008 Vstrom DL 1000
post #7 of 11 Old 09-18-2012, 09:50 AM
You need the battery.
post #8 of 11 Old 09-18-2012, 06:59 PM Thread Starter
ok, well this is fubared. my troller has a flashing red light, not solid.
cant find anything on the site?
2008 Vstrom DL 1000
post #9 of 11 Old 09-18-2012, 07:10 PM
My Gerbing will blink at less than full on. Have you turned the knobs all the way both ways?
At full on the gerb will get warm enough to cook me.
post #10 of 11 Old 09-18-2012, 07:27 PM Thread Starter
got it figured out, was doing synch wrong. all good.
now I need bigger gloves to fit my liners!
2008 Vstrom DL 1000
