Vstom computer project - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 08-07-2012, 04:35 PM Thread Starter
I have wanted to do this for sometime, I then took the plunge and bought an arduino kit, and away I went.
over the course of a few weeks I experimented, tweaking and testing.
I have a partial working prototype just waiting on addtion modules as nothing i could find locally.
right now it have dubbed it MIC (Motorcycle Information Center)
it has:
Outside temp
Gear Postion Indicator
GPS (simulated as this is on its way)
Direction (N, S NW etc)
speedo
Long/Lat
Time (may remove if i find something that is needed/wanted more.
All of this on a nice 128x64 LCD display (and moving to possibly a color touch screen which I have on order)
The gear position indicator I have simulated with a poteniometer using the actual vstrom gear voltage readings
Here are some pics of the prototype
Arduino Motorcycle computer
I have powered this on my DL650 already with no issues. once I get my GPS module I will have to test it in my car.
Jim
DiscusZ-V is offline
post #2 of 17 Old 08-07-2012, 05:48 PM
BrianTRice's Avatar
Very cool. I'm a software developer with some electronics/embedded background so have considered a similar project. I have the DL650AL2 "Glee" so the GPI and temperature sensors are available if still in a proprietary system.
The project I envision would get some data out of that into an iOS or Android mobile device, and maybe allow a basic 5-button controller to attach to the left handgrip. Arduino is a good board for that sort of thing but I haven't explored this much.
BrianTRice is offline
post #3 of 17 Old 08-08-2012, 02:06 AM
xDownSetx's Avatar
Have you guys thought about using a Raspberry Pi? Considerably more powerful and runs on Linux. Only requires power from usb and almost as small as an arduino for $25.
'06 Silver DL1000
xDownSetx is offline
post #4 of 17 Old 08-08-2012, 03:08 AM
banditrider's Avatar
Very impressive. I wish I had the skills to play around with stuff like this...
'08 Vee: Suzy luggage, Crash bars, Rad Guard & front mudguard extension, Zumo 550, Oxford Hot grips, Stebel, PC-8, 12v acc, Scott oiler & lube-tube, Remus Revolution Cans, Bark Busters, Phillips Extreme vision +100 bulbs.
'08 Concours 14: Rad guard, Stebel, Oxford Hot grips, Projekt D Screen, Hugger, GPS mount, helmet locks & front guard extension, Zumo 550, Stebel, Phil's rack & Givi V46, Sheepskin seat cover, Phillips Extreme vision +100 bulbs.
http://banditrider.weebly.com/index.html
http://banditrider.blogspot.com/
banditrider is offline
post #5 of 17 Old 08-08-2012, 05:25 AM Thread Starter
I have never done any electronics what so ever I think the Raspberry Pi would be more difficult to do this without being able to easily add modules (GPS, etc) I have not looked much into the Pi, but when i researched this, i felt the ardunio would be easier
I would love to get some sort of dial switch (like on the new BMW touring bike, to control the screen (change screens, etc) So one can use the whole screen for one item like compass, or somethjing alone those lines.
I know I still havea way to go, once my GPS module arrives from Canakit, the testing, and porduction will move forward. then its figuring out how to enclose this into a waterproof case for the screen, and whether to keep it al together or have the screen alone, and connected via cable to the arduino.
I have come a long way with this.. I started simple, used LEDs inplace of the screen as I did not have it
next will be figuring how to read the Gear Voltage on the bike.
Its been alot of fun and has kept me outa trouble when I can not ride the bike LOL now I also have other projects I want to build with this time, and not motorcycle related, some are aquarium related
jim
post #6 of 17 Old 08-08-2012, 03:10 PM Thread Starter
Just added a no lock push button to my prototype and my device now has multiple display screens
So now one can have the current info screen with a lot of info, or show just the GPI and Speed.
Next will be setting itup so one can select what they want on the screens, for now i will hardcode what I want on each of the 4 screens, and cycle through with 1 button.
this took less than 5 mins to wire up and code.
post #7 of 17 Old 08-08-2012, 03:46 PM
Ol_Baldy's Avatar
I'm following your project with great interest
:lurk5:
I love seeing these gadget projects for the Strom. My main interest is a Gear indicator and the outside Temperature (F and C). My GPS provides the rest of the info I need. Good luck with the size and packaging.
By the way, have you seen BigMan73's similar project here?
Shiro nakama nijuu-ni - White Wee-Strom #22
'10 - DL650A (still my main trekker)
'11 - Suzuki DR-Z400sm (now modded as a Funduro)
'15 - Kawasaki Concours 14 (the Green Monster)
'65 - Honda Cub 50 (gone long ago but not forgotten)
Ol_Baldy is offline
post #8 of 17 Old 08-08-2012, 07:17 PM
BrianTRice's Avatar
I haven't seriously considered it yet. The demand has been so high that I thought to just wait a while before evaluating it. The lion's share of any of this work is in wiring in the data/control inputs, anyway.
post #9 of 17 Old 08-10-2012, 01:54 AM Thread Starter
my GPS module is sitting at the post office so now I get to try actual GPS data rather than simulated data.. wish it was open right now..
post #10 of 17 Old 08-12-2012, 01:56 PM Thread Starter
GPS module added on Friday, tweaked GPS code took until into my truck and went for a spin, amazingly accurate to my vehicle speedo, with in a micro second it shows the same speed, direction heading works, lat/long next is gear postion on bike. then case, and mounting and done. they tweak code to make it smaller as I would love to record GPS info for putting on google earth or something showing trip path and altitude.
Tags
computer
