Get oem acc. outlet or make my own? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 07-18-2012, 05:19 AM Thread Starter
Just getting some opinion. Right now it looks like i want an outlet up front, and every connector i have with the exception of my battery tender is a cigarette lighter.
Is it worth the 60 bucks for OEM? I was thinking of connecting a walmart/autozone/whatever plug, drilling a hole in a flat spot, and running it to the battery with an inline fuse. I've got wires, just need an inline fuse (i think radioshack plugs come with a fuse holder and i would just put whatever amps i need in it)
Uses: primarily a cellphone charger and a slime air compressor to keep the tires aired up whenever i need 'em inflated.
Any reason to pay for the oem? Or would a radioshack plug be just fine?
Alexi
sfalexi is offline
post #2 of 7 Old 07-18-2012, 07:17 AM
No reason to go OEM. The two on my '07 were from Wal-Mart.
post #3 of 7 Old 07-28-2012, 10:35 AM
Send a message via MSN to BikeBugger Send a message via Skype™ to BikeBugger
if it helps, I got this from an electronics retailer...
BikeBugger is offline
post #4 of 7 Old 07-28-2012, 11:49 AM
Ditto on the cheap cigarette type outlets. Mind you, even with a rubber cap on them they can get a bit corroded after a while. But they still work. I even picked up a two headed jump cord so I can run the GPS and charge the phone.
post #5 of 7 Old 07-28-2012, 12:24 PM
tmcgee's Avatar
Buy the marine version.
tmcgee is offline
post #6 of 7 Old 07-28-2012, 01:48 PM
LoneStrom's Avatar
I use a double outlet from Oreileys.They are water proof??,and they last me about 1 year and then they get to corroded to ues.I put bullet type connectors on them so replacement only takes around 5 minutes AND they only cost around $10 !!!.
Sent from my Motorcycle iPhone app
1990 Yamaha XT350
2012 Honda NC700X BDR express......
1994 GS500..DORA THE PURPLE EXPLORA
LoneStrom is offline
post #7 of 7 Old 07-28-2012, 02:49 PM
I just googled 'marine power outlets' and found Oprtonics outlet for $5.95. That's about the same cost as the cheapies from Auto zone and probably a better choice!
