Scala Rider G9 & Zumo 660 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 06-28-2012, 09:13 AM Thread Starter
Has anyone been able to figure out how to shut off the beep that occurs when you touch the screen on the 660? There is no option to shut only the beeps off. You can shut off navigation commands, and you can shut off media. You can also mute all- which does indeed stop the beeps- But if you mute all, you cannot listen to music! I used to listen to music from my cell phone, but the G9 only accepts one BT source at a time. I purchased the Zumo so I could hear the voice commands for navigation instructions. The touch screen beep interrupts the intercom... so every time I touch the screen, the intercom stops and takes 20 seconds or so to re-establish.
I might need to return the Zumo? Wahhh.
'04 Vstrom 650
L12B12E12 is offline
post #2 of 2 Old 08-06-2012, 10:15 PM
StromNC's Avatar
Hmm, hadn't really noticed that. I have a G9 and a Zumo, but rarely use the intercom feature. Maybe I don't touch the screen as often as you. The Zumo is a great unit, but I can see how that would be annoying. If you find a good solution let's hear about it.
StromNC is offline
