go pro mount - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 06-11-2012, 05:13 PM Thread Starter
cannonrider's Avatar
Question go pro mount
Has anyone ever mounted your go pro camera on handguard with 3m mounting plate? if so did it hold up? I was thinking about fluid resivour mount,but with wide lens I thought windscreen might blur pics.Any other suggestions ?????
cannonrider is offline
post #2 of 9 Old 06-11-2012, 05:28 PM
tmcgee's Avatar
The 3M stuff will hold just about anywhere, the problem is keeping the camera from shaking or you get the jello effect.
tmcgee is offline
post #3 of 9 Old 06-11-2012, 05:41 PM
bwringer's Avatar
Agreed -- you need something to deal with vibration.
Since I already have RAM mounts on my bikes and some spare RAM hardware lying around, that's what I used and it works great. A RAM mount looks like a 1" diameter rubber-coated trailer hitch, and there are various arms and accessories that attach to it. The rubber does a nice job of damping vibration.
Very little "jello", even on a KLR650:
Gatesville to Nashville, Indiana - YouTube
Mounted to a 4-cylinder bike, chasing my Vee:
nc2011p1.wmv - YouTube
Mounted to my Vee -- should have pointed it more forward and out away from the instruments. It takes a while to get used to the fisheye lens.
bc2011becksmillroad.wmv - YouTube
The vibration is mostly from bumps in the road and not the engine.
bwringer is offline
post #4 of 9 Old 06-11-2012, 09:05 PM
CHIA's Avatar
Man, that guys is ALL OVER the road, new rider? The camera bike, not you
CHIA is offline
post #5 of 9 Old 06-12-2012, 03:00 AM
banditrider's Avatar
If you want to mount it on your clutch or brake reservoir then you can get a ram mount that bolts onto the reservoir cover. Mine's on the clutch side and gets a bit of a view of the dash (including speedo - doh!) and then the road ahead. No real vibration issues - the GoPro is pretty good at sorting that out.
Apologies for crap pic of camera mounted - the best one I could find:
Plenty of vids here: exbanditrider - YouTube
'08 Vee: Suzy luggage, Crash bars, Rad Guard & front mudguard extension, Zumo 550, Oxford Hot grips, Stebel, PC-8, 12v acc, Scott oiler & lube-tube, Remus Revolution Cans, Bark Busters, Phillips Extreme vision +100 bulbs.
'08 Concours 14: Rad guard, Stebel, Oxford Hot grips, Projekt D Screen, Hugger, GPS mount, helmet locks & front guard extension, Zumo 550, Stebel, Phil's rack & Givi V46, Sheepskin seat cover, Phillips Extreme vision +100 bulbs.
http://banditrider.weebly.com/index.html
http://banditrider.blogspot.com/
banditrider is offline
post #6 of 9 Old 06-12-2012, 01:06 PM
CHIA's Avatar
The only issue I had with this set-up, was the camera hitting the windscreen when I turned the bars hard right at slow speeds.
CHIA is offline
post #7 of 9 Old 06-12-2012, 04:03 PM
If I set mine up right then that doesn't usually happen. Usually only an issue at maximum lock.
post #8 of 9 Old 06-12-2012, 04:10 PM
CHIA's Avatar
Ya, that's where mine was, at max lock.
CHIA is offline
post #9 of 9 Old 06-12-2012, 05:41 PM
bwringer's Avatar
Definitely not a new rider, and much quicker than average, but yes, he was visibly struggling to keep up.
We had a chat later about staying in one's comfort zone lest one become the star in a "EPIC FAIL!" video...
I was mainly concentrating on being smoooooooooth to give my wife a thrilling, safe ride. Mission accomplished -- she had a blast.
bwringer is offline
