Heated Gear, GPS, & Voltmeter ??? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 03-03-2012, 01:21 PM Thread Starter
I had a couple of finger reattached after a mishap with a snowblower, so it looks like heated gloves are going to be a must from now on. My 08 Wee is bone stock as far as the wiring is concerned. If I am going to add wiring for gloves, I may as well wire it for a heated jacket liner and GPS while I am at it. I thought a voltmeter would also be a good idea. I do not have much experience with electronics, but I am able to read and follow instructions.
My goal:
Gerbing heated liner and G3 gloves plugged into two panel mounted ports on the plastic panel near my left thigh. They would be controlled by a Gerbing Permanent Dual-Temp Controller mounted on a Richland Rick's Auxillary Shelf. This would be powered by switched circuit.
Garmin Zumo 660 powered by an unswitched circuit. I probably wouldn't use a fraction of the gizmos that this unit is capable of, but it seems like the most up-to-date version of a motorcycle specific GPS.
Datel or Koso digital voltmeter mounted on the Rick's Shelf powered by a switched circuit.
The gloves are going to be my #1 priority, but I want everything in place when I decide to purchase the heated liner and GPS. I apologize for so many questions, but I really want to do this right the first time.
Questions:
Will I need a Battery Tender if I am riding with heated gear? These fingers are very sensitive to the cold and I will probably be commuting (5-10 minutes) at least 4 months out of the year with heated gloves. I rarely ride in Dec-Feb.
Will an Eastern Beaver 3CS with one circuit unswitched be enough if I don't need a Battery tender or should I get the PC-8?
Are there any disadvantages to the V Strom version that uses the rear brakelight connector vs tapping into the switched connector under the tank?
How will I know which size of fuse to use for each circuit?
If I purchase the gloves first, they include a Y-Harness. Does this harness run up under my jacket and down the sleeves? Does it stay in the jacket between the jacket and insulated liner or will I have to reinstall it everytime I pull the wires out when I take the jacket off. Would I be better off buying the heated liner and the gloves at the same time to save the hassel of the Y-Harness?
The wires for the Garmin Zumo 660 appear to be connected to the cradle. Is there a socket on the back of the GPS that plugs into the cradle? What should I do with the cables that I am not using? Can I run them back under the seat and zip tie them out of the way until I want to use them some day?
Datel or Koso voltmeter? Judging from the instructions, it looks like the Datel is mounted in a hole cut in the panel and the Koso is mounted with velcro.
Flat Black Club Member #160
WFRTony is offline
post #2 of 8 Old 03-07-2012, 10:10 PM
toronto_nic's Avatar
i mounted my datel with velcro. works fine
2008 Vstrom DL 1000
toronto_nic is offline
post #3 of 8 Old 03-08-2012, 12:45 AM
cwvet's Avatar
I have a similar set up. Get the PC8, you will not regret it. The PC3 will be quite limiting and for a few extra bucks, you can have an 8 which allow you to expand in the future. If you are ordering from eastern beaver, check out the H4 relay.
DL 650 ABS 2008 Madstad, Rifle windscreen, Scott's stabilizer, Oxford heated grips, RR fork brace, Jessie's
WR 250F 2008
cwvet is offline
post #4 of 8 Old 03-09-2012, 09:36 AM Thread Starter
Does the H4 relay make more watts available or does it just make the headlights brighter?
The temps hit the mid 60's the other day and I got impatient and ordered the 3CS before you posted the PC-8 recommendation.
I am now considering an unswitched Powerlet socket on the Rick's shelf. Eastern Beaver makes a Powerlet cord for the Zumo cradle, and I believe I could also use the Powerlet socket for a Battery Tender or an air compressor.
WFRTony is offline
post #5 of 8 Old 03-09-2012, 10:40 AM
Headlight relays keep the stock headlight wiring from self destructing over time and get about one additional volt to the lights instead of heat to the wiring.
post #6 of 8 Old 03-09-2012, 08:59 PM
larolco's Avatar
Originally Posted by WFRTony View Post
My goal:
Questions:
The Y-harness stays inside your jacket. However, I'd recommend getting a jacket liner at the same time as the gloves. Then the gloves plug directly into the liner sleeves, making the Y-harness redundant.
Also, give the new G5 gloves a look. They have heat in the palms which the G3 gloves do not. I've got the G3's and, while they're okay, I prefer the older classic gloves that Gerbings no longer makes (better insulated but bulkier). If I were to buy another pair, it would be the G5's. I think they're about $20 more.
I run my supply wires out between the seat and gas tank. I've never bothered to install jacks. This way, the plug-in is close to your jacket liner port and remains flexible.
DRZ400SK17
larolco is online now
post #7 of 8 Old 03-13-2012, 08:03 PM Thread Starter
I will probably order a liner when I decide on which gloves to get. I tried on the G3's at the motorcycle show; now I wish I had looked at the liners and G5's when I was there. Running the wire through the notch at the front of the seat looks a lot easier and more convenient than installing permanent jacks. Thanks for the advise!
WFRTony is offline
post #8 of 8 Old 03-14-2012, 12:36 AM
larolco's Avatar
If you really want to go fancy, just buy a Gerbings jacket. The liner zips in. I've got the old Cascade jacket. Their newer stuff looks even better. I've got the XE pants. Here's a link to the XE jacket (pricey, but if you ride a lot in the cold and wet like I do, worth it):
Gerbing's Heated Clothing // Heated eXtreme Element Jacket
DRZ400SK17
