datel voltmer installation - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 12-27-2011, 03:58 PM Thread Starter
toronto_nic's Avatar
Hello,
just received my datel volt meter
2 questions:
1- what is the proper cable gauge I should be using for the install?
2- Does it need to be fused or installed to my Beaver box, or directly to the battery?
2008 Vstrom DL 1000
toronto_nic is offline
post #2 of 17 Old 12-27-2011, 05:32 PM
Voltar's Avatar
I have not installed that voltmeter, but...
You can run small wires. The voltmeter (like all good voltmeters) has a high input impedance and therefore draw almost no current.
But... It does draw some current so I would not recommend attaching it straight to the battery because it, of course, will pull juice from the battery all the time.
As far as where to connect; put it on a circuit that is 1) switched on with the key and 2) doesn't have a heavy load like the headlights on it..
Voltar is offline
post #3 of 17 Old 12-27-2011, 05:35 PM
LordSmoke's Avatar
Datel voltmeter installation and usage questions
2014 BMW R1200GSW (APR14 - )
LordSmoke is offline
post #4 of 17 Old 12-27-2011, 05:53 PM
tmcgee's Avatar
Originally Posted by toronto_nic View Post
Hello,
2 questions:
Wire size is not critical. 18 ga. is heavy enough. I don't recall where I connected mine, just that it's only on with the ignition.
tmcgee is offline
post #5 of 17 Old 12-27-2011, 10:49 PM
ozart's Avatar
Although that volt meter draws minuscule current, it still needs to be switched. As said, 18ga or larger wire should be sufficient, if connected inline with the battery - although I use 16.
I use a manual switch for mine as I like to know the voltage without the ignition on - for diagnostic purposes, which is the purpose of the meter.
ozart is offline
post #6 of 17 Old 12-28-2011, 09:35 AM Thread Starter
can you recommend a switch?
2008 Vstrom DL 1000
post #7 of 17 Old 12-28-2011, 02:11 PM
ozart's Avatar
I used one similar to this.
but again, due to the very low current draw, any automotive maintained rocker switch will do. Your local auto parts dealer should have a variety to choose from.
Here's an example of what's available.
ozart is offline
post #8 of 17 Old 12-28-2011, 02:51 PM
Fyrman's Avatar
You can get them here in Canada at The Source
They carry 3ways as well but I wasn't able to find one in store, I got mine at a local industrial electronics store.
[SIGPIC][/SIGPIC][quote=Bwringer]It's a feature, not a bug.[/quote]
Fyrman is offline
post #9 of 17 Old 01-21-2012, 07:28 PM
I don't get it. Why "switch" a volt meter, as long as it's on the ignition. what's the need? The switch gives you something else that can fail. The only "switch" on my volt meter is the ignition key.
sweetcreek is offline
post #10 of 17 Old 01-21-2012, 08:19 PM
Flying Pig's Avatar
It's useful to know what your battery's standing voltage is at. 12.9 is the maximum, 11.4 at the minimum (assuming no failed cells).
If your battery can only hold 12.3v, you'll probably notice that it's going to be hard to start. Can be useful to know stuff like that when wondering why your having starting issues as it's not always the battery's fault and it can help with the diagnosing.
Saves you from having to pull out a multimeter....
[SIZE="1"]When was the last time you checked your tire pressure?[/SIZE]
Flying Pig is offline
