Connecting to ECU - What protocol? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 07-12-2011, 06:40 PM Thread Starter
BigMan73's Avatar
I'm really interested to know how do the ECU dealer device and after market ECU devices connect to the ECU.
What communication protocol is it? Is there documentation for that?
I wonder what types of information are available - oil pressure? engine temp? etc.
2015 Triumph Tiger 800 XCx
2011 DL-650A, Now owned by another stromtrooper
Stromputer - https://www.stromtrooper.com/dl650-2004-2011/73806-stromputer-alive.html
Stromtrooper Wiki - http://stromtrooper.wikispaces.com/
BigMan73 is offline
post #2 of 12 Old 07-12-2011, 06:53 PM
I wonder if it's the same as the 'Busa?
ecueditor.com - ultimate gsxr superbike ecu flash tuning software by petrik
I think the protocol is SDS (Suzuki Diagnostic System).
Here's a decent older thread that discusses the tool GW is talking about below:
https://www.stromtrooper.com/dl650-sp...-greywolf.html
WVeeStrom is offline
post #3 of 12 Old 07-12-2011, 07:05 PM
Basically, if there is a sensor, its readout can be checked. The oil pressure sender is a go/no go unit rather than a measuring device so the tool won't provide oil pressure. Oil and coolant temperature is taken off the sensor that feeds the temp display so there is a reading there. The SDS system is proprietary. Suzuki will only sell it to dealers and licensed repair shops. Healtech has what they call an OBD tool that we can get. It's fun to play with but I haven't found anything I really need it for other than to figure out the TBS I had done at a dealer didn't need updating.
HealTech Electronics Ltd. - Makers of the SpeedoHealer, GIpro, X-TRE, FI Tuner Pro, OBD Tool
post #4 of 12 Old 07-12-2011, 07:07 PM Thread Starter
BigMan73's Avatar
Great reply!
I found this as a result:
Suzuki DL650 V-Strom k7 Diagnosis Bus - ECU hacking
SDS protocol - ECU hacking
Kind of dirty low level details, but very interesting.
BigMan73 is offline
post #5 of 12 Old 07-12-2011, 07:13 PM Thread Starter
BigMan73's Avatar
Thanks.
Let me share with you my thoughts - The new Glee-Strom has some nice new additions to its dash board.
I was thinking, why not retrofit a Wee-Strom with such a module that would display such information?
I'm not into a commercial product, but an open source DIY project - programming an AVR or PIC microcontroller is not that complicated.
A proprietary SDS Protocol is an issue - it may take some time to fully reverse engineer. I was hoping for a something more open.
As for healtech and the other ecueditor (GSXR), I guess they reversed engineered the protocol (perhaps not fully), to get the FI Codes.
BigMan73 is offline
post #6 of 12 Old 07-12-2011, 07:20 PM
I could mount a small computer and use it but all I'd want in addition to what Suzuki provides is a voltmeter. Gear position, voltmeter and ambient air thermometer and the only readouts I added to my bike.
post #7 of 12 Old 07-12-2011, 07:25 PM Thread Starter
BigMan73's Avatar
Yes, I agree.
I was planning to add a microcontroller with an LCD display..I can still display these measurements.
Did you buy them off the shelf, or develop your own custom solution?
BigMan73 is offline
post #8 of 12 Old 07-12-2011, 07:28 PM
Yes, I agree.
I bought them.
post #9 of 12 Old 07-12-2011, 07:53 PM Thread Starter
BigMan73's Avatar
I bought them.
For gear indicator I found this cool DIY article (for Suzuki):
Gear Indicator Plans
I still need to figure what TRE is, and also where the gear voltage can be found on the v-strom (EDIT: Found it - Gear Position Sensor Connector http://www.jackphelps.com/vstrom/gipro.htm), but comparing voltage on a microcontroller is very easy, using an analog-to-digital port.
Ambient temperature is also easy - can be done analog, or using I2C protocol.
Volt meter - another A2D measurement.
The LCD display can be communicated over I2C (simple) - so the whole project shouldn't be over complex.
I currently have an Lego NXT [Robot], which has a big smart microcontroller - so I would probably use the NXT as my microcontroller at least for the prototype.
It has full support for I2C and A2D..perfect..
Also has support for motors - I could move the MadStad up and down some how.. :biggrinjester: (that's science fiction..)
Last edited by BigMan73; 07-12-2011 at 09:14 PM. Reason: Found Gear Position Sensor Connector
BigMan73 is offline
post #10 of 12 Old 07-12-2011, 08:07 PM Thread Starter
BigMan73's Avatar
For those interested in NXT/I2C: an article by Sivan Toledo, a really smart & creative Israeli professor I2C Interfacing Part 1: Adding Digital I/O Ports (Lego Mindstorms NXT)
BigMan73 is offline
