GPS Blanking out - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 07-03-2011, 05:33 AM Thread Starter
biddysere's Avatar
GPS Blanking out
I did a hot wire job from the battery to my gps acc. plug-in and now when I plug in the gps, the screen goes haywire. I can take the same gps and put it back into my truck and it works fine. Any suggestions?
biddysere is offline
post #2 of 6 Old 07-03-2011, 07:25 AM
Did you cut a cigarette lighter plug off the the wire to connect the wire to the battery? If so, that plug has a 5V regulator in it. The GPS is getting 12V instead of 5V.
If that isn't the problem, check that the polarity is correct.
post #3 of 6 Old 07-03-2011, 03:28 PM Thread Starter
biddysere's Avatar
Thanks. I'll get the polarity checked and see if that's it
post #4 of 6 Old 07-03-2011, 07:03 PM Thread Starter
biddysere's Avatar
OK, Appperantly I am getting 12 v to the plug ins instead of 5v. I think I need to find where that extra wire by the radiator is that everyone talks about and wire into that
post #5 of 6 Old 07-03-2011, 07:22 PM
That's still 12V. You need the cigarette light plug with the 5V regulator or another 12V-5V converter.
post #6 of 6 Old 07-03-2011, 08:52 PM Thread Starter
biddysere's Avatar
Ok. Well, I had it wired this way for 2 years and it worked. I guess I got lucky. I think I will have to wait at this point until I get home and double check. I didn't cut the plugs off so if there is a online 5 v converter, i will make sure these are still ok. Thanks for all the help, let you know tomorrow if I have sucess!
