small LED volt meter - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 03-18-2011, 08:00 PM Thread Starter
Since the electrical system seems to be the weak spot on the V-Strom (DL1000) = Does anyone know where I can find a small, cheap, LED volt meter that will fit under my radar shelf?
There's some on ebay (12 to 15 bucks) but they don't give the size and the seller isn't forth coming.
Thanks, DeOldfart
sweetcreek is offline
post #2 of 12 Old 03-18-2011, 09:17 PM
andreas's Avatar
Volt Meter
Here's my volt meter I just mounted 2 days ago, the same model is on my wifes Versys.
I tried it below the shelf, didn't like it there, really couldn't see my highbeam indicator, or neutral
A litle drilling, remounting the 'L' bracket to the top
FB MEMBER #133 - 2008 Wee
andreas is offline
post #3 of 12 Old 03-18-2011, 09:30 PM
jayDL is offline
post #4 of 12 Old 03-18-2011, 11:47 PM
Heavy's Avatar
Search for the Kuryakyn one.
Small, around $30.00 and works well.
Yes, it comes in black as well as the chrome.
DL1000K6
Heavy is offline
post #5 of 12 Old 03-19-2011, 12:02 PM
Sharkey's Avatar
Send a message via Yahoo to Sharkey
Datel volt meter
I have a Datel digital VM that I installed about 3 years ago. No problems so far. Go to Datel .com for info
Sharkey is offline
post #6 of 12 Old 03-19-2011, 12:15 PM
Keep water out of the 5 function meter Andreas. It isn't exactly waterproof. I have mine tucked away under the instrument panel and that's worked pretty well.
post #7 of 12 Old 03-20-2011, 06:44 AM
pso
I have aa Escort Pasport radar detecor that has digital Votage read out. Nice bright red numbers and also if it drops below a certain level gives audible signal. Mounted detector on shelf. Worked well on godlWing, Buell and now Wee.
pso is offline
post #8 of 12 Old 03-20-2011, 09:51 AM
andreas's Avatar
I knew the unit wasn't very water proof. Mainly designed for use inside a vehicle. I'll look at the bike to see how you mounted yours in that spot.
The one on my wifes Versys is not as exposed, I have hers attached to the shield bracket. I am still looking for a clear plastic pill box style container
andreas is offline
post #9 of 12 Old 03-20-2011, 09:36 PM Thread Starter
THANKS!!!
Thanks guys!! I can now spend some more $$$ on my V-Strom
signed: DeOldfart
post #10 of 12 Old 03-21-2011, 08:38 AM
andreas's Avatar
signed: DeOldfart
Yeah - I know what you mean.... This Forum just enables my Farkle addiction
andreas is offline
