??? fuse size ???? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 03-08-2011, 06:38 PM Thread Starter
??? fuse size ????
hey folks, What size fuse do you suggest using in my accessory / power outlets. I have two on seperate circuits and plan using my GPS, charge my cell & a radar detctor and dats all folks..........
My Russell day long has a 7.5 for the heated seat.
Thanks, deOldfart
sweetcreek is offline
post #2 of 4 Old 03-08-2011, 08:04 PM
Use the fuse that protects the size of wire you run to the outlets, up to the maximum capacity of the outlet. #14 wire=20 amp; #16=15 amp; #18=10 amp. (This is higher than house wiring, 'cuz the wire isn't wrapped in a 6" fiberglass insulation overcoat and won't heat up as much.)
post #3 of 4 Old 03-08-2011, 08:30 PM
maggot's Avatar
I have a fuseblock that has seperate circuits for the GPS and radar. I can't recal of top of my head the exact fuses but both combined are probably less than 5amp. a 2amper would be enough for a gps.
2007 DL650 Gray
maggot is offline
post #4 of 4 Old 03-09-2011, 12:04 AM
dtalk's Avatar
I like to use the smallest fuse that will work for the connected equipment. For the devices you listed, I'd start with 1A and go up only if I had to.
dtalk is offline
