Satellite Radio - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 09-07-2010, 02:25 PM Thread Starter
rcacs's Avatar
Satellite Radio
Just installed a Sirius radio on my Wee. It actually works pretty decent. I have the Cardo Q2 set up, so it was simple to recieve the FM signal thru the included wireless FM on the Cardo.
The Sirius comes with a quasy-RAM type mount, although I am going to replace it with the real McCoy.
For power (5 VDC), I ran the plug under the tank so I can plug it into the cig lighter type plug I have under my seat. The antenna is affixed on top of my front brake master cylinder. The antenna is magnetic, so I glued a small washer to the cylinder cover.
A winter project will be to find and install better helmet speakers than what come with the Q2.
Cheers!
rcacs is offline
post #2 of 16 Old 09-08-2010, 03:18 PM
pippinsdad's Avatar
I too have a Sirius radio mounted on my Wee, paired with a Cardo Systems G4 headset. Are you able to get a strong enough FM signal from your Stratus 6 to reach your Q2 without static? I couldn't get a strong enough FM signal out of my radio's internal transmitter, so I bought an external transmitter by iSimple that works much better. I also now use the direct wired method of the audio out from the Sirius to the mp3 input of the G4, which sounds much better than the FM method. I used to have the Q2 and the mp3 input was not nearly as good as on the G4. It now has volume control from the headset.
DL650K9 ABS
pippinsdad is offline
post #3 of 16 Old 09-08-2010, 04:36 PM Thread Starter
rcacs's Avatar
Actually, its a Stratus 5, but I have no problem recieving the signal from even 5 or 6ft away from the bike. I tried the direct wire right to the Q2 didnt really notice any diff, so stay with the wireless. I can control volume on the Q2 pod, but dont recieve stereo. If I have my IPod wired, I do get stereo.
Cheers!
rcacs is offline
post #4 of 16 Old 09-08-2010, 07:10 PM
Heavy's Avatar
What do you need tunes on your bike for? Its not like you spend any time riding it. :biggrinjester:
DL1000K6
Heavy is offline
post #5 of 16 Old 09-08-2010, 07:16 PM
Cheers!
The only way to top that setup will be for me to install a nice DVD system! :=)
DL650k9 Orange
TomDevlin is offline
post #6 of 16 Old 09-09-2010, 07:26 AM
pippinsdad's Avatar
I'm assuming Canadian Sirius radios have a stronger FM transmitter than the ones sold in the U.S.. The FCC forced Sirius in 2006 to weaken their FM transmitters to a very weak level that barely travels 1 foot without major static.
DL650K9 ABS
post #7 of 16 Old 09-09-2010, 11:40 AM Thread Starter
rcacs's Avatar
My hope is to someday find time to ride more often. :beatnik:
Cheers!
rcacs is offline
post #8 of 16 Old 09-09-2010, 11:50 AM
Heavy's Avatar
Cheers!
That's the spirit! Take that garage queen out and get some use out of it.
...miserable underachievers.... :rolleyes5:
DL1000K6
Heavy is offline
post #9 of 16 Old 12-09-2010, 02:25 PM
Cool, I have XM radio through my Garmin GPS.
craig196 is offline
post #10 of 16 Old 12-11-2010, 07:09 PM
pso
I also have xm radio through Garmin GPS.
pso is offline
