Helmet audio - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 09-05-2010, 02:59 AM Thread Starter
Helmet audio
I have been looking for some way to get ear phones or buds in my helmet without having to chop up the inner lining when I stumbled on this Home - Tunebug Portable Speaker with SurfaceSound Technology not sure if they are available yet. It mounts onto the outside of the helmet. It is wireless, bluetooth. There are three models, one even has a mic so you could talk to your passenger or answer your phone.
Any one seen one of these yet?
Harry
Ventured is offline
post #2 of 10 Old 09-05-2010, 03:23 AM
BDragon's Avatar
that's freakin retarded! get a real comm setup. some helmets have built-in spots for speaker placement like the shoei multitec or hornet ds.
Givi Windscreen, Madstads, E21 & E41 Panniers, E52 Top Case, Scorpion Stainless Exhaust, Famsa Tank Bag & Panniers, Symtec heated Grips w/ Grip Puppies, Pat Walsh Engine Guard / Skid Plate, OEM Handgaurds, OEM Center Stand, SWMotech Mirror Wideners, Metzler Tourance, 4" ABS Tube, AutoCom Pro 7, GIPro, Sargent Seat, BSS Fuse Block & Relay, Garmin Zumo 550, Stebel Air Horn, Aux Powerlets, Alaskan Leather, PIAA xtreme white, Superbrace, ToolTube, Kaoko Throttle Control, Highway Pegs, Risers (1" up 1" back) Sonic Springs, 1" raising links, PIAA 510 ATP, Touratech LED Tail Light, Touratech Zumo mount.
BDragon is offline
post #3 of 10 Old 09-05-2010, 08:46 AM
Heavy's Avatar
Originally Posted by BDragon View Post
that's freakin retarded!...
Now, let's be forum appropriate.....its "Wee-tarded".
DL1000K6
Heavy is offline
post #4 of 10 Old 09-05-2010, 08:52 AM
exploring/carolina's Avatar
When installing Autocomm speakers & mic, used additional foam to shim the speakers out to my ears, tie wraps to secure mic & cable. No other modifications were required.
Bill
2008 DL650
exploring/carolina is offline
post #5 of 10 Old 09-05-2010, 05:29 PM
p38arover's Avatar
I ride with ear plugs so I wouldn't hear those speakers very well.
So what about custom fit ear plugs with earphones moulded in? Our local bike shows always have someone making them on the spot - or you can buy kits to make them at home.
See, for example, DIY Custom Ear Plugs, You Will Wear Them Because They Fit
Ron B. VK2OTC
2007 Yamaha XJR1300
RIP Bucko
1979-2008 - Riding on forever
p38arover is offline
post #6 of 10 Old 09-05-2010, 11:10 PM
maggot's Avatar
Lots of folks use custom earbuds with success.
I have the autocomm with speakers and have them shimmed perfectly to the point that as I'm putting on my modular helmet I pull apart the sides a little as I'm pulling the helmet down over my head. Once the helmet is on, the speakers cover my ears nicely but without pressure. Blocks out external noise well and the sound that comes out of them is great!!!
Ken
2007 DL650 Gray
maggot is offline
post #7 of 10 Old 09-06-2010, 01:12 AM Thread Starter
OK not too much support for the Tunebug.
My problem is I also wear glasses and already have some difficulty getting them on, I'm afraid that adding speakers would further complicate the matter. The search continues.
Ventured is offline
post #8 of 10 Old 09-06-2010, 04:08 AM
I'm in the same boat...eyeglasses and my preferred helmet (Shark rsr2) has no room to put speakers in. I have worn earbuds underneath the lid but they get uncomfortable very quickly if I can even manage to get the helmet on without pulling them out.
I have a buddy who tried the diy earplug material on a set of buds and it didn't work well. It's also not important enough for me to drop more than 40 or 50 bucks on, so I may never have a solution.
milq is offline
post #9 of 10 Old 09-06-2010, 09:39 AM
Ear Fuse kicks A$$. Easy to make, custom fit, sound good. All thumbs up.
themastermike is offline
post #10 of 10 Old 09-06-2010, 01:36 PM
maggot's Avatar
I too wear glasses and IMO a modular helmet is a must. No interference between the speakers of arms of the glasses. I have my glasses on and can easily put on/remove helmet and the glasses stay put.
Ken
2007 DL650 Gray
maggot is offline
