Wireing block? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 05-06-2010, 08:53 AM Thread Starter
RC4MAN's Avatar
Wireing block?
Anyone recommend a good waterproof combo wireing/fuse block for accessories.
RC4MAN is offline
post #2 of 9 Old 05-06-2010, 09:22 AM
SCraig's Avatar
Waterproof? No.
Good? Yes. Either Blue Seas or Centech.
Scott Craig - Nashville, TN
SCraig is offline
post #3 of 9 Old 05-06-2010, 09:30 AM
Send a message via AIM to TedSki Send a message via Yahoo to TedSki
If you're going to put it under the seat where most do (and where there is tons of room to do so), waterproof isn't a huge issue. Even if it gets wet during water crossings, its still fine. Your biggest enemy at that point would be corrosion, which can be taken care of when cleaning the bike (if you do that sort of thing).
TedSki :: 2004 V-Strom 1000
TedSki is offline
post #4 of 9 Old 05-06-2010, 09:44 AM Thread Starter
RC4MAN's Avatar
Thanks for the suggestions
RC4MAN is offline
post #5 of 9 Old 05-06-2010, 10:51 AM
yamak's Avatar
also consider
the pc 8 from eastern beaver, very compact for under seat install.
yamak is offline
post #6 of 9 Old 05-06-2010, 11:03 AM
PMC
I've also using the EB PC8
compact and easy to install
PMC is offline
post #7 of 9 Old 06-04-2010, 09:17 AM Thread Starter
RC4MAN's Avatar
Bought and installed the EB PC8.
Install was easy and straight forward. Have since added air horns, battery charger, Dyno-Jet PC III and a couple 12 VDC power outlets through the unit, all very easy as well.
RC4MAN is offline
post #8 of 9 Old 06-11-2010, 02:45 PM
I've got a Fuzeblock FZ-1 installed on my Wee. I like the fact that it's got the relay built-in, and their clever technique of being able to change a circuit from "switched" to "unswitched" (i.e., always on) simply by moving the fuse over.
Having said that... The total capacity ain't great, and I'm probably going to bypass it when I install the 20A headlight relay, just using an inline fuse. I probably would've gone with the Eastern Beaver box, had it not come out two weeks after I got the FZ-1...
skyguy is offline
post #9 of 9 Old 08-12-2010, 11:39 PM
Installed Electrical Connection's power block and ground. mounted under the seat and in a small tupperware container for water resistance. Chris..........
cddjake is offline
