Using the passing switch as the PTT on our comms... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 03-17-2010, 03:23 PM Thread Starter
Quehele's Avatar
We have Midland two-way radios with AVPH2 closed face speaker/mic systems. The system works very well in general. PTT switch is mounted on the left mirror.
I've taken both bikes (wife has a DL650, I have a DL1000) left controls apart and re-purposed the passing switches to act as PTT switches for the comms. The problem is they don't work.
Upon close examination I noticed a very small chip, either a resistor or a diode, on the Midland PTT switch. Is this chip (or the lack of it) my problem? When I key the mike the circuit opens and transmits, but only open air...there's no sound from the mic.
Has anyone else done this mod successfully?
Jim
Wife's '09 DL-650: OEM hand guards - DL-1000 lower cowel - 16t counter sprocket - Givi windscreen - Air box mod w/ K&N air filter - GIPro gear indicator w/ ATRE - integrated comm system.
My '09 DL-1000: Air box mod w/ K&N air filter - GIPro gear indicator w/ ATRE - integrated comm system - Givi windscreen.
Quehele is offline
post #2 of 8 Old 03-22-2010, 11:52 AM Thread Starter
Quehele's Avatar
Never mind. I figured out how the system works.
The system works better than ever actually. Clear, clean and simple.
Quehele is offline
post #3 of 8 Old 03-22-2010, 12:01 PM
$orry $ucka
perfectstranger's Avatar
Send a message via Yahoo to perfectstranger Send a message via Skype™ to perfectstranger
What was the problem? I don't have a comm setup but like the idea of using the passing light switch as PTT. Have yet to use that switch to warn drivers that I'm overtaking them. If anything, I give the horn a little toot...probably as useless as a flash of the lights.
perfectstranger is offline
post #4 of 8 Old 03-22-2010, 12:14 PM
sapperranger04's Avatar
:lurk5::lurk5::lurk5:
--- SAPPERS FORWARD ---
K7 VEE / ?
K5 WEE / SGT. Strom
K6 KLR650 / Ol Thumpy
K6 KLX110
81 KLE100
sapperranger04 is offline
post #5 of 8 Old 03-22-2010, 01:36 PM
CHIA's Avatar
It would be a good idea to share this, in detail with others, seems like a great idea.
I don't use the passing switch ever, and don't have a requirement for an intercom, but I'm guessing many here would really appreciate some specifics on how you did it.
CHIA is offline
post #6 of 8 Old 03-22-2010, 01:49 PM Thread Starter
Quehele's Avatar
You've got a point. I have an advantage over many in that I used to be an electrician...and the boards have been there when I've need info.
I'll put something together in a day or two. Take care.
Quehele is offline
post #7 of 8 Old 04-19-2010, 08:34 AM
andreas's Avatar
I would like to know what you did. Could you tell us please?
FB MEMBER #133 - 2008 Wee
andreas is offline
post #8 of 8 Old 10-14-2010, 09:12 AM
Fyrman's Avatar
Any updates on this??
[SIGPIC][/SIGPIC][quote=Bwringer]It's a feature, not a bug.[/quote]
Fyrman is offline
