RAM Aquabox Question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 01-21-2010, 08:11 PM Thread Starter
I just purchased an Aquabox for my Nuvi 1490 T. Anyone have any experience running the wires to the GPS? It seems like you would need to drill into the plastic
Thanks for any thoughts
2007 V Strom 650
cgingras1 is offline
post #2 of 16 Old 01-21-2010, 09:34 PM
$orry $ucka
perfectstranger's Avatar
Send a message via Yahoo to perfectstranger Send a message via Skype™ to perfectstranger
Don't have mine handy but aren't there punchouts on the backside underneath the mounting plate with the ball? Won't be able to get to mine until tomorrow. It's buried in storage right now, sorry bro.
perfectstranger is offline
post #3 of 16 Old 01-21-2010, 10:02 PM
maggot's Avatar
I cut a notch out on the shoulder that's on the back of the box. I then drilled a hole large enough for the cable to pass through. The notch is on the bottom of the shoulder and the hole is near the top. Once the ball plate is screwed on you can only see the notch from the outside.
Hope this helps. I can take a pic if the above doesn't make sense.
Ken
2007 DL650 Gray
maggot is offline
post #4 of 16 Old 01-21-2010, 10:54 PM Thread Starter
If its not too much trouble a picture would be very helpful
They have a punch out in the back for the cable but that is exactly where the ball connection goes so I think that is useless.
My plan was to basically do what you describe
Thanks for the comments. Very helpful
2007 V Strom 650
post #5 of 16 Old 01-21-2010, 11:14 PM
V-Tom's Avatar
I don't have mine handy, but if I recall correctly you do punch out in the middle and the cord goes through the little maze behind the mounting plate. That helps stop water from running into the unit. I have ridden my bike in severe rain with no issues of water getting to my iPod.
..Tom
SMIDSY detailed report.
V-Tom is online now
post #6 of 16 Old 01-21-2010, 11:40 PM
$orry $ucka
Could also squeeze a grommet into that hole and make the port (when wire is running through it) pretty damned water tight. It helps immensely to have the round mounting plate with ball because it covers the whole backside mounting area on the aquabox.
post #7 of 16 Old 01-22-2010, 12:27 AM
maggot's Avatar
Correct. I thought about just drilling a hole into the box itself. But making it near the mount with the ball plate covering in is a much better solution. Also, I didn't want to use the punch out as it would leave a bigger hole then I needed.
I'll take a couple pics tomorrow...
Ken
2007 DL650 Gray
maggot is offline
post #8 of 16 Old 01-22-2010, 10:00 PM
maggot's Avatar
RAM Mount pic
Ken
2007 DL650 Gray
maggot is offline
post #9 of 16 Old 03-04-2010, 10:36 PM
Which Aqua Box did you get? The AQ6?
Tred is offline
post #10 of 16 Old 05-21-2011, 11:23 AM
thread revive..... I just got a 1490t and need an aqua box. what model did you guys get? Thanks!
Megathumper is offline
