LED - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 01-20-2010, 06:54 PM Thread Starter
LED
Is it possible to wire a supplimental LED brake light bar into the existing brake light wire? Does it require more electronics than that?
Denase is offline
post #2 of 5 Old 01-20-2010, 06:59 PM
Mr.Metal's Avatar
Yes. http://admorelighting.com/index.php?....php&subpage=4
The hookup requires using the Posi-Lock and Posi-Tap connectors that come with the kit to splice into the brake light wiring. However, you can also get a kit from Eastern Beaver to help you with that: http://easternbeaver.com/Main/Bike_S...raketailsignal
2008 DL650 a.k.a. Road Warrior, member #16 of the Flat Black Club
2009 Aprilia Tuono 1000R a.k.a. Silver Thunder
Mr.Metal is offline
post #3 of 5 Old 01-20-2010, 07:02 PM
ro_manian's Avatar
sure is. Just splice or connect the aux wire to the existing brake wire.
That's how I connected the LED brake light on the Kappa top box.
If your LED light is just a supplemental light, there's no need of using diodes or anything like that. Depending on your LED light setup, you might need to connect the + to + and - to - , otherwise it wouldn't work. Some LED light setups have some more electronics involved inside, and It wouldn't matter if you mix the wires, it would still work. But, maybe that's too much info already!
ro_manian is offline
post #4 of 5 Old 01-20-2010, 07:38 PM Thread Starter
Thanks
Thanks for the replies. I was just about to order a led light bar to mount in addition to the factory brake light, when I read. (Logic circuit required) sold separately.
Denase is offline
post #5 of 5 Old 01-20-2010, 07:45 PM
Check out Hyperlites. They come with all the fixin's and work very well.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
