Locating rear brake connector - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 08-02-2009, 02:12 PM Thread Starter
lscroggs's Avatar
I have a 2005 Wee which I've had for four months and just finished installing a three circuit power block from Eastern Beaver. I got the complete 3 circuit V-Strom kit so it would be plug and play with no wire cutting.
I had a hell of a time finding the rear brake connector on my bike. I looked and looked. I took my laptop out to the garage and compared photos from the forum to my bike. I read and re-read the postings on this forum. I could not find the connector where others have found it. Many people said it was under the coolant expansion tank so I removed the left side (from the rider's point of view) L shaped black plastic piece and found the coolant tank but no connector. Finally it looked like I would have to remove or at least lift the fuel tank to find the connector. I didn't really want to do that because the tank is almost full. I removed the right side L shaped black plastic piece opposite the coolant expansion tank. I shined a flashlight under and behind the fuel tank and there, tightly under and against the rear tank brace, was the rear brake connector. The gap I was looking through was the only way it could be seen without lifting or removing the fuel tank. Then it was just a matter of slipping my hand in, disconnecting the connector, and plugging in the Eastern Beaver connector. A piece of cake.
From my research on this site, it appears that the brake connector can be in various places depending on the type of V-Strom: Wee or Vee, ABS or not, and model year. The general area, between the battery box and the engine, is the same, but the specific location varies. As I stated, my bike is a 2005 Wee without ABS. The easiest way to get to the rear brake connector on my bike is to remove the right, L shaped, black plastic piece and reach through the gap to under the rear fuel tank brace.
I cannot speak highly enough about Jim from Eastern Beaver. His products are first rate and he has been very helpful in showing me which of his products I need to install my Stebel horn, BackOff XP brake light adapter, and sockets. He has been quick to answer my questions. I'll definitely be doing business with him again.
Larry
Larry
2005 V-Strom DL650
lscroggs is offline
post #2 of 5 Old 08-02-2009, 03:38 PM
silverstrom's Avatar
When I installed my 12V plug I ordered from Easter Beaver. It's a great place to do business. I ordered from Canada and had the package within a week.
SS
DL650K7
1985 RZ500
1986 NS400R HRC
1987 RG250
1987 TZR 250
1988 RGV 250
1989 RZ 350 F2
1990 RZ 350 N2
silverstrom is offline
post #3 of 5 Old 08-02-2009, 06:34 PM
truax's Avatar
When installing my Eastern B relay mine was just behind and below where the tank is anchored to the frame... not far from the battery.
Jim has been VERY helpful over the years, ordered two relays in the last two weeks.
Truax
[SIZE="2"]DL 1000K9[/SIZE]
Former Bikes:
2008 Concours 14
2007 Triumph Bonneville
1982 Kawasaki 440 LTD
1977 Yamaha 750 XS
truax is offline
post #4 of 5 Old 08-03-2009, 11:47 AM
Just installed a PC8 from E.B. yesterday and everything went more smoothly than I expected.
Don't know how you managed to reach that connector though. There was no way to get my fingers in there to grab and disconnect it. I planned a bit in advance and decided to change the air filter at the same time. Trust me, with the fuel tank off, its all pretty easy!
Rob in T.O.
K7 DL650 ABS
WeeRob is offline
post #5 of 5 Old 08-09-2009, 09:16 PM
F16Viper68's Avatar
Lord at least none of you mis-read the online directions and took apart the rear fender in an effort to locate the rear brake connector. :cursing:
Once I was able to find this thread it still took me a bit to find the connector. I ended up doing a tank lift, unbolting the rear tank mounting bracket, and holding up the assembly while disconnecting and re-connecting.
Ok, who puts a rear brake connector under a fuel tank?
Dave...
2008 V-Strom 650 Black (sold)
2012 Super Tenere
F16Viper68 is offline
