My GPS keeps burning fuses?? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 07-24-2009, 09:28 AM Thread Starter
Bamaboy's Avatar
Fuses are cheap but I am getting tired of changing them. They are good for up to one month. I have the GPS wired directly to my battery.
I am also going to be installing a Radar Detector. Is it okay to direct wire it to the battery also? I am electronically challenged.
2004 Silver V-Strom 1000 & 1994 Yamaha XT600
Farkles? Sargent Seat, Genmar risers, K&N filter, cramp buster, heated grips, PCIII, Givi Engine Guards, Givi Hard Bags 52 liter and two 45 liter, Givi shield with spacers for buffeting.
Bamaboy is offline
post #2 of 3 Old 07-24-2009, 11:46 AM
Dread7's Avatar
Might I ask if you have any type of 12 volt adapter plugged inline? I believe that 12v adapter you put in the cig lighter/data adapter hole provides more than a connection to the electronics. I believe it's a simple regulator also so you are always supplied 12v and not more. When you rev up you could possibly achieve up to 17v depending on how your system is charging the battery. That is a possibility on why you are blowing fuses.
Maybe, if you don't have one, you could put one inline?
Formerly clovett but changed to my gaming name
2004 DL650 1998 DR650 1994 CB1000 1992 DR350
2004 Z400 1965 Norton 650 1984 Honda XL200
1975 Suzuki RM125 1972 Yamaha 100 enduro
1971 Honda CT90 1968 Honda Z50A
Dread7 is offline
post #3 of 3 Old 07-24-2009, 11:59 AM
wendortb's Avatar
Send a message via MSN to wendortb
I would start by checking the wire to make sure it hasn't been sliced or something. I would completely pull the wire out and check it over very carefully.
Could also be your mount has a short in it.
08 DL650A
wendortb is offline
