Garmin Nuvi 260w Mount/Charge - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 07-22-2009, 09:46 AM Thread Starter
I have a Garmin Nuvi 260W and I was wondering if there's a motorcycle mount for it. No such thing on the Garmin website, they want you to buy the $700 GPS that is made specifically for bikes.
I've read in some other posts here about a RAM kit, but I have no idea what it is... when I google it, all that comes up is computer RAM.
The GPS itself has a Automobile, Bicycle or pedestrian mode, does that mean it won't be so good for a motorcycle?
Also is there anyway to charge it? The charger it comes with hooks up to a cigarette lighter. I didn't find anything from the manufacture for charging on a bike either. I am open to any ideas or suggestions.
ocara is offline
post #2 of 16 Old 07-22-2009, 10:59 AM
jccc's Avatar
I use this same mount for my Garmin Nuvi 350, works great. I run my unit off the battery last about 6-8 hours.
Here is the link for your GPS. If you order, you can save I believe 5% by entering RAMLIVECHAT in the coupon box.
http://www.gpscity.com/ram-mount-gar...olt-mount.html
I'll tell you this, no eternal reward will forgive us now for wasting the dawn.
jccc is offline
post #3 of 16 Old 07-22-2009, 01:39 PM
KZDon's Avatar
You might also try bodging something together with whatever car mount you have for your Garmin. Don't try using the suction cup on your motorcycle windshield, but for a while, I used cable ties to hold my Garmin i5 onto the brake reservoir, and then later up on the dash, using the cable ties through an unused windshield bracket bolt hole.
For other possible solutions, though, try googling "Nuvi 260 RAM mount" or "Nuvi 260 Motorcycle Mount". The second one there just netted this - meant for a bicycle but looks like it would work well. http://www.mountguys.com/product_p/010-11011-00.htm
KZDon is offline
post #4 of 16 Old 07-22-2009, 02:20 PM Thread Starter
Thanks for such quick responses! I would never try the suction cup, I've had it fall out the window and almost down the highway in the car, can't imagine what would happen on a bike.
How do you do that? I am new to the whole motorcycling world so the more detail the better! Thanks again
ocara is offline
post #5 of 16 Old 07-22-2009, 08:30 PM
maggot's Avatar
I use this for my Nuvi 260..
http://www.gpscity.ca/ram-mount-wate...olt-mount.html
I also have a 12V power outlet mounted on my top triple tree to power the GPS. I can also plug in any other 12V accessory such as a small air compressor.
Ken
2007 DL650 Gray
maggot is offline
post #6 of 16 Old 07-22-2009, 08:48 PM
stevestrom's Avatar
I use a 200 series Nuvi on my bike and I would highly recommend installing a 12V plug in for it. When plugged in the screen becomes noticably brighter than when just running off the internal battery alone (much easier to see in the sunlight, IMO).
I use a Ram mount I ordered from Mountguys.com. Good service from these guys and the Ram products are great!
stevestrom is offline
post #7 of 16 Old 07-22-2009, 09:16 PM
desertwolf's Avatar
I used one of these for 10,000+ miles on my old bike and it worked without issue. It was great and cheap, only $12.99.
http://www.amazon.com/IG-B01A-i-Trek...8311648&sr=8-2
desertwolf is offline
post #8 of 16 Old 07-23-2009, 07:28 PM Thread Starter
Wow now I have a lot of options to consider as far as the RAM mount goes.
I am still wondering how you install a 12v plug or connect something directly to the battery.
ocara is offline
post #9 of 16 Old 07-23-2009, 10:05 PM
maggot's Avatar
It's a basic install..
Being talked about right now in the General Forum
https://www.stromtrooper.com/showthread.php?t=42776
Biggest problem is deciding on where you want the outlet and if you want it switchable or Hot..
Good luck
Ken
2007 DL650 Gray
maggot is offline
post #10 of 16 Old 08-19-2009, 10:28 PM Thread Starter
I just ordered mine. The coupon code you mentioned does work! Thank you so much! Once I receive it and get it installed I am going to start looking into getting a 12v plug connected.
ocara is offline
