RAM mounts - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
post #1 of 22 Old 09-01-2019, 08:34 PM Thread Starter
RAM mounts
Hey guys so since I got my V-strom I got my first phone mount. Everyone talks about the RAM mounts so I figured I'd get one. Got the Strombone and mounted behind the windscreen and put a RAM x-grip on a short arm. The RAM ball system is excellent, no movement. The RAM x-grip device is junk. I HATE it. Every few hundred feet the slight bumps and such in the road cause my phone to rotate and I have to reach up and straighten it. It is aggravating. What am I doing wrong?
2007 Kawasaki KLR650 (Sold)
2007 Yamaha FZ6 (Sold)
2006 Yamaha FZ1 (Sold)
2003 Honda 919 (Sold)
2012 Suzuki V-Strom 1000
Delasangre is offline
post #2 of 22 Old 09-01-2019, 09:17 PM
offwegoagain's Avatar
Pretty common issue, it was pissing me off at the beginning, later I got used to it. You could put some gel pad behind the phone to create more friction between the X-grip and the phone. From my experience the twist, if occurs, is minimal when you hold your phone by the upper half to help mitigate the issue with the help of good old gravity. The benefit of the mount is that fits literally everything.
Custom signature...
offwegoagain is offline
post #3 of 22 Old 09-01-2019, 09:35 PM
One option is to get rid of the xgrip and get that phone mount from Hondo Garage. If you put a ball on their mount you can still use the short arm you have now. I have the xgrip on my wee and the Hondo mount on my DRZ which is very secure despite some pretty rough terrain.
MrF likes this.
2017 V-Strom 650
2012 DRZ 400
Jhat is offline
post #4 of 22 Old 09-02-2019, 01:49 AM Thread Starter
Good lord that's expensive!
post #5 of 22 Old 09-02-2019, 02:41 AM
The Xgrip comes with the x rubber that fits over the four corners of the phone. I usually just hook it on two corners. No problems with movement after that. Without using tether with the xgrip the phone will constantly rotate. The tether should have come with your xgrip, but if for some reason you don't have it you can buy for $4. See Photo. My xgrip and tether have lasted 3 years in use in all kinds of weather
File Type: png Screen Shot 2019-09-02 at 1.51.50 AM.png (201.2 KB, 22 views)
richlandrick and Webfors like this.
Inpitt/Mac50 is offline
post #6 of 22 Old 09-02-2019, 02:44 AM Thread Starter
It came with but it doesnt fit my phone. RAM website recommend the regular size X-grip for my phone. The X does fit with a bit of room to spare but the tether is not even close. Feel like I should have got the XL
post #7 of 22 Old 09-02-2019, 08:42 AM
PineLaneRider's Avatar
https://ocmounts.com/products/ram%C2...RoCqcAQAvD_BwE
Much better holder. Much less than PS.
richlandrick likes this.
PineLaneRider is offline
post #8 of 22 Old 09-02-2019, 10:12 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
That looks interesting. I'll put some on order.
richlandrick is offline
post #9 of 22 Old 09-02-2019, 11:06 AM
drrod's Avatar
I use an X Grip with my Samsung Galaxy S7 and while it does occasionally rotate, it is usually due to me bumping it with my arm when turning ignition on, etc. I have used it on some pretty rough roads and it holds the phone well. The issue I have with the X-Grip and my phone is that if I center the phone in the grip, it will push the volume and on/off buttons so I have to mount it low on the phone. Other than that, no issues.
Anyone have a good idea on how to stabilize the usb charging connection when hooking the cable to the phone?
drrod is offline
post #10 of 22 Old 09-02-2019, 11:37 AM
oldjeep's Avatar
Never had that issue with mine, but I always use the rubber tether around 2 corners.
Chuck P
2004 DL1000
2003 FZ1
www.oldjeep.com
oldjeep is offline
