RAM mounts - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
post #11 of 22 Old 09-02-2019, 12:10 PM Thread Starter
Originally Posted by PineLaneRider View Post
https://ocmounts.com/products/ram%C2...RoCqcAQAvD_BwE
Much better holder. Much less than PS.
I'm waiting for the extra large version to become available, I'm honestly not sure why they wouldn't both come out of the same time, I've sent an email to them to ask when.
2007 Kawasaki KLR650 (Sold)
2007 Yamaha FZ6 (Sold)
2006 Yamaha FZ1 (Sold)
2003 Honda 919 (Sold)
2012 Suzuki V-Strom 1000
Delasangre is offline
post #12 of 22 Old 09-02-2019, 12:16 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
I think personal tolerance plays a large part here, but the rubber retainer does help with the X-grip. I get by without it, but have a increased the spring rate on my over the dash shelf.
Esheufelt likes this.
richlandrick is offline
post #13 of 22 Old 09-02-2019, 11:20 PM
Originally Posted by Delasangre View Post
It came with but it doesnt fit my phone. RAM website recommend the regular size X-grip for my phone. The X does fit with a bit of room to spare but the tether is not even close. Feel like I should have got the XL
I have the iphone 8 plus with a Lifeproof waterproof case on it to protect in foul weather use. I use the xlarge ram holder and tether with the 8 plus . The regular xcross or tether won't fit the plus. The Lifeproof case also have extension tabs at the corners that makes the tether hold even stronger.
Inpitt/Mac50 is offline
post #14 of 22 Old 09-03-2019, 01:48 PM
I had the same rotating issues, I remedied it by turning the xgrip ever so slightly, so that with the phone in the mount, there is a hard stop one of the two directions it can rotate. Its hard to describe but just messing around with it I was able to figure it out. This pretty much stopped the phone from rotating over rough terrain but it does still occasionally happen as it does have space to rotate if it gets going. I should really try the rubber tether, maybe that will fix the issue all together.
CrazyAirborne is offline
post #15 of 22 Old 09-08-2019, 12:56 AM
OP, I'm not sure why your phone cradle is rotating slightly every time it hits a bump as mine stays where I place it. Yes it rotates slightly, but only when I move it. Initially I hated that but it's necessary for the way it's designed and I got used to it and occasionally find it a handy feature.
On a slightly different topic, I place a small square of Velcro or substitute, with the soft side on the phone and the hook side on the cradle. It helps keep the phone locked in the cradle when placing the phone in it.
baroquenride is offline
post #16 of 22 Old 09-08-2019, 12:59 AM Thread Starter
So RAM sent me a bigger tether since the one that came with my mount didn't fit my phone. I will try it out, but I am still waiting for the other new version of their mount.
post #17 of 22 Old 11-19-2019, 04:50 PM
NGreenSxrambler's Avatar
If you have an iPhone 7 or older, all it does is put it to sleep/ reset it by squeezing on the top half. If you hold at the mid level, it is lowering the volume of your music/ maps talking through your phone if you have it connected bluetooth. If you hold it at the bottom, is is not balanced enough to hold in place and always falls off. I can't run this mount on my bicycle or my motorcycle. Is it just the phone or what?
When the rain is away, I am on the road!
NGreenSxrambler is offline
post #18 of 22 Old 11-19-2019, 08:39 PM
Webfors's Avatar
My favourite holder. Had it for years on my wee. Unfortunately it won't hold the newer/bigger phones without some unorthodox mods.
For the x-grip, I had the same issue. The key was loosening the neck and rotating/adjusting it to compensate for the predictable rotation. No issues now.
Two wheelz for realz!
'18 DL1000XT
Webfors is offline
post #19 of 22 Old 11-19-2019, 08:43 PM
PineLaneRider's Avatar
PineLaneRider is offline
post #20 of 22 Old 11-19-2019, 08:51 PM
Webfors's Avatar
Perfect! Thank you! I am ordering this asap. If it's the same quality/function as the original it will be most excellent.
The X-grip just got demoted to car duty
'18 DL1000XT
Webfors is offline
