Aux lights and H4 socket - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 06-16-2019, 08:15 AM Thread Starter
So the kids got me a set of auxiliary lights for Fathers Day. I have the EB H4 relay kit installed so have the extra socket taped up and out of the way. Can this socket be used to power the aux lights? Or is it best to skip this altogether and feed directly from the battery?
Thanks!
Long time rider, first time V-Strom owner
2015 DL650A, Candy Daring Red (mine)
2015 Honda CBR300RA, Matte Black (my wife's)
Skinner is offline
post #2 of 4 Old 06-16-2019, 08:20 AM
Dark Angel's Avatar
Depends on the current draw of the aux lights. If it's as much or more than what the high beam would have been drawing from the loom without the relay kit you'd be better off using a relay and going direct from the battery. If it's less than the stock high beam the wiring and switches will cope fine.
Dark Angel is offline
post #3 of 4 Old 06-16-2019, 09:15 AM Thread Starter
So if I connect directly to this H4 socket do I need to plug into both lo and high beams? I'd like the aux lights to be on at all times.
Skinner is offline
post #4 of 4 Old 06-16-2019, 11:16 AM
blaustrom's Avatar
If you basically short circuit the low and high beam wires you may get some unexpected results, at least I would be worried without really studying the wiring diagram. Plus no way to turn them of, which at some point you may want to or need to do.
Better to wire them to a fuse box (on with the ignition on) and put a switch in-line to be able to turn them of.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
