Heads Up voltage monitor - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Skinner
post #1 of 4 Old 06-11-2019, 01:12 PM Thread Starter
I bought one the Heads Up voltage monitors to install on my 2015 DL650A. I used the included wire taps to connect to the marker light wiring (small light above the headlight). However, this location is very tight and the wire is quite short - I was unable to get a good squeeze on the tap so one has come loose. Can anyone suggest a better spot to connect behind the fairing?
Thanks!
DesertBike likes this.
Long time rider, first time V-Strom owner
2015 DL650A, Candy Daring Red (mine)
2015 Honda CBR300RA, Matte Black (my wife's)
Skinner is offline
post #2 of 4 Old 06-11-2019, 02:49 PM
chicago's Avatar
I connected mine to the accessory outlet right side fairing on my '13 DL 650. It was probably 6 years ago so can't recall if I bought/needed a special connector to access it. I would have got the connector from Eastern Beaver. A dealer should carry it also. I would add wire as needed. I always use https://www.posi-products.com/ to connect wire to wire. Not sure which voltage monitor I have. I zip tied the led to my throttle cable. Just ordered a voltage monitor 'electrical connection' brand from twisted for my DR 650.
14 tooth for me
chicago is offline
post #3 of 4 Old 06-11-2019, 03:25 PM Thread Starter
I thought about that. I have the Eastern Beaver accessory connector but it's currently feeding my USB charging port.
Skinner is offline
post #4 of 4 Old 06-11-2019, 04:13 PM
chicago's Avatar
you can use it anyway. it can do both.
14 tooth for me
chicago is offline
