Connecting heated grips wire and fuse block - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 07-13-2009, 04:30 PM Thread Starter
YukonTracker's Avatar
I am looking at hooking up a fuse block to a switched circuit for fog lights, Oxford grips etc. I know Eastern Beaver caters to that end with some neat stuff (just ordered the heated grip connector) but I would like to just simply wire in a small fuse block and keep cost for simple things down. Allot of folks seem to tap into the tail light wiring for a switched connection. Could the factory heated grip connector be used for this? Besides location I cannot come up with any problem. On a previous dismantling I already freed up the connector a bit for future considerations.
YukonTracker is offline
post #2 of 3 Old 07-13-2009, 04:32 PM
Sure. It can be used as a trigger for a relay to control a fuse block.
post #3 of 3 Old 07-14-2009, 10:30 AM
I hooked mine up this way. It seemed a little funny to run a wire from the heated grip connector to my underseat fuse box and then back to the heated grips, but I already had the heated grip adapter on hand.
WeeVee is offline
