Eastern Beaver PC-8 Use Question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 3 Post By RCinNC
  • 1 Post By BigSky
post #1 of 3 Old 04-10-2019, 01:39 PM Thread Starter
BigSky's Avatar
I've successfully installed the EB PC-8 on my 2017 DL650 XT. The one device I added was my grip warmers and I did that while doing the installation. At that time the main fuse(s) between the battery and the PC-8, per the instructions, were not installed. That actually made sense; but, brings up this question. When adding additional devices/wiring to the PC-8, is it necessary to remove the main fuses between the battery and the PC-8?
BigSky is online now
post #2 of 3 Old 04-10-2019, 02:10 PM
RCinNC's Avatar
Well, if you pull the in-line fuse between the battery and the PC-8, then there's no power in the fusebox. You remove the risk of shorting something by inadvertently touching something with a tool that you shouldn't have touched when you're connecting it to the PC-8. Could be especially important if you're installing some type of electronic device. I wouldn't say it's necessary; just an added precaution.
Stalky Tracker, SECoda and eff like this.
RCinNC is offline
post #3 of 3 Old 04-10-2019, 04:56 PM Thread Starter
BigSky's Avatar
Thanks RC, I speculated as much. Having the fuse out while flinging around all of the wires to connect the PC-8 actually made perfect sense as does your provided information.
RCinNC likes this.
Eastern Beaver and Twisted Throttle eaglefrq General V-Strom Discussion 3 10-16-2012 09:38 PM
Eastern Beaver - Opinions Needed of my plan Strange Dog Techy World! GPS, Electronics, etc 4 10-10-2012 02:51 PM
Eastern Beaver 3CS vs new PC8 fuse box rockitcity Maintenance, Tech and Products. 16 10-14-2011 09:12 PM
HID lights and Eastern Beaver H4 relay harness Yak Techy World! GPS, Electronics, etc 3 04-30-2011 02:24 AM
eastern beaver headlight modulator wiring question larolco General V-Strom Discussion 15 01-01-2008 09:39 PM
