Clearwater Driving Lights Problem - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Yarz1
post #1 of 7 Old 12-22-2018, 01:35 AM Thread Starter
mjt57's Avatar
I have a set of Clearwater driving lights on my Vstrom 1000. They were on the bike when I bought it (second hand). However, now they are playing up.
Basically, from the rider's perspective there are two controls; an on/off switch and a "dimmer" control.
When switched on, the dimmer can vary their brightness. However, the lights have a tap into the headlight's high beam. So, when you go to high beam the driving lights shine at their maximum brightness.
On high beam the brightness can't be dimmed.
Lately, they've been playing up. I noticed that despite the headlight being on low beam the DLs were at their max brightness. The dimmer wasn't working, and when riding, I could see the light being reflected off of road signs. And they looked like they were flickering.
So, when I got home I checked them out. I flicked high to low. DLs stayed bright. Dimmer didn't work on low beam.
It's as if the input from the high beam is "high" or on.
I've managed to get a wiring diagram off of Clearwater. But I don't know if it's for my lights. They have a few different ones and they all seem to be wired differently.
I'll have to look at dismantling the bike, something that I'm not looking forward to doing, as I've not done it before and I don't know how to do so without a workshop manual.
https://www.manualslib.com/manual/95...?page=9#manual
Hopefully someone here is familar with them and can give me a trouble shooting guide.
Thanks
Work to ride, ride to work...
mjt57 is offline
post #2 of 7 Old 12-22-2018, 01:19 PM
MJT57, it seems as if your dimmer is going bad. In reality, those are not dimmers in the standard sense, but are pulse width modulators (PWM). If your LED lights are flickering, the PWM is not quite right. Which Clearwater lights do you have? Is that a Clearwater PWM for that set of lights? Is it waterproof, or has it possibly been exposed to weather beyond its capabilities? Clearwater sells some great lights! If they don't have a PWM for the set of lights you have, or if they don't have a PWM to replace yours, I would recommend you contact Jason over at LEDRider.com. Tell them what you have and see what PWM they might advise.
richlandrick likes this.
Yarz1 is offline
post #3 of 7 Old 12-22-2018, 01:44 PM
I had a similar issue with relay controlled LED headlights and battery monitor a few months ago, not with driving lights and dimmer though. Somewhere in the hook up a ground had lost it's solid connection. I tightened all the grounds and added a separate ground from the fairing area/farkles to the battery ground and all was well. You might want to check all ground connections involved. Especially if you were not involved in the initial installation. Just my 2 cents..... Merry Christmas!
John
fuller1956 is offline
post #4 of 7 Old 12-22-2018, 02:13 PM
Hogges's Avatar
Hard to see how it could accidentally trigger high beams from this wiring diagram. Might be the electronics are fried.
Hogges is offline
post #5 of 7 Old 12-22-2018, 03:48 PM
trapperdog's Avatar
Mjt, do you by chance have LED bulbs in the headlights? They can cause problems with the high beam function of the clearwaters but rarely the low beams. FYI, Clearwater’s set to high via the volume control knob ( PWM) on low beam will only be at %75. Only on high beam will they go to %100 and are not dimable. There are two trigger wires for %100, one taps into the high beam wire and one into the horn. Some bikes require an extra diod installed inline of those wires. I’ve installed four sets of a Clearwaters and had an additional two sets installed on our BMW’s at Clearwater and have never had any problems. Your best bet would be to pull the plastics and examine all the wiring and if everything is kosher, contact Clearwater via phone or email.
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
trapperdog is offline
post #6 of 7 Old 12-22-2018, 08:35 PM Thread Starter
mjt57's Avatar
Thanks for the feedback, folks. It's appreciated. I'm not able to start stripping the bike down just yet. I also have to identify the lights that I have fitted. When I get more info I'll post it here.
mjt57 is offline
post #7 of 7 Old 12-22-2018, 08:48 PM Thread Starter
mjt57's Avatar
The former owner just texted me a minute ago. Kresta is the type, he wrote. And he told me who fitted them.
I have to take the bike there for a service and to get the ECU recall done, so hopefully the mechanic who installed the lights is still there.
mjt57 is offline
LED driving lights and DOT regs BobAgain V-Strom Modifications and Performance 2 05-25-2012 07:14 AM
Mounting points for driving lights... UBarW DL650 and DL650A - 2004 to 2011 19 05-03-2012 03:13 PM
HID driving lamp problem Dave650 Maintenance, Tech and Products. 4 08-05-2009 09:15 AM
PIAA vs Hella driving lights mypetduck DL650 and DL650A - 2004 to 2011 56 05-20-2009 12:18 PM
35 watt bulbs for driving lights nvr2old V-Strom Modifications and Performance 4 02-11-2008 03:53 PM
