Mounting an Action Cam - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 17 Old 12-16-2018, 11:23 PM Thread Starter
Hey Guys,
I bought an impulse buy of a $50 go pro knock off. It has tons of accessories, but I can't figure a good way to mount it in front. Any ideas? The one idea that would work is to use an adhesive mount right on top of the master cylinder on the right brake. Do you think that's a bad ideas?
FatCobra is offline
post #2 of 17 Old 12-17-2018, 12:21 AM
marcham's Avatar
I have a few bolt on and one clamp on mount. So far, I prefer left handlebar or rear side rack as mounting points.
Sent from my SM-T590 using Tapatalk
2015 VSTROM 650 X ABS EXP
marcham is offline
post #3 of 17 Old 12-17-2018, 12:35 AM
Brockie's Avatar
Firstly, please include your bike and location in your profile details - it just makes it so much easier for others.
What mounting position/method works for some may not work for others. Vibration is also a big issue. There are a couple of threads here https://www.stromtrooper.com/techy-w...-question.html and here https://www.stromtrooper.com/techy-w...-dashcams.html
Some have them sitting on or under the beak. The current position of mine is in the attached image. The plus is that the rubber padding under the clamp reduces the vibrations. However, I also get a lot of very whiny engine noise. I have also tried the bars, the brake master cylinder and the mirror stalk. The best picture was when I attached the camera via a car windscreen sucker to the front of the faring except that the wind noise was bad and it also fell off a few times.
I will move your thread to that section.
Brockie is offline
post #4 of 17 Old 12-17-2018, 11:26 AM
PerazziMx14's Avatar
I too had issues finding a good spot where to mount. Handlebars, helmet, crash bars, panniers all posed issues for me. I ended up using a stick on quick mount centered just above headlights.
PerazziMx14 is offline
post #5 of 17 Old 12-17-2018, 12:48 PM
BigBlue505's Avatar
I've had the best luck with chest mount. You have to wear it up high to see over the dash on these bikes. It isolates the camera from the bike vibration and reduces some wind noise being behind the fairing. My camera's also a cheap Chinese Go-Pro knockoff.
BigBlue505 is offline
post #6 of 17 Old 12-17-2018, 01:56 PM
Null 13's Avatar
That is suuuuch a hard question.
I have a mount socket on top of my helmet (low speed panorama style shots), and one on the right side of it (moderate to low wind). I also install the bike mount on the side of the bike under the crash bar (much less winds, less vibrations) for more spirited rides.
Best way is to hold (or even better, have someone else hold) the camera where you think it would look good, and watch on your phone/tablet through live view to see if you like the angle. Then hope for the best, because not all cams have good image stabilization/anti shake.
Good luck.
________
2014 VStrom 1000 Adv SE, because army bikes are more adv
Null 13 is online now
post #7 of 17 Old 12-17-2018, 11:16 PM
booghotfoot's Avatar
I mounted my action can on the side of my helmet. It records what I'm looking at. Rarely get bug guts or road grime on it. I expected to feel the drag on the side of my helmet but it was negligible. It didn't add much noise to my ride either.
Other locations I tried in front or to side of windscreen ended up with all kinds of crap obstructing the image.
No matter where you mount it, the camera will pick up a lot of noise...wind or engine. I just mute it at playback and overlay it with music.
Finally, my cheapo unit has a wireless pushbutton switch to turn it on and off. I velcro'd it to the handlebar. I can just barely hear the camera beep as it cycles on when riding. I miss shots on nearly every ride assuming its on when its not.
OK, one more suggestion...get a pack of spare batteries and charging station. The cameras suck juice!
Sent from my YY-107H using Tapatalk
There are 10 kinds of people: those who understand binary and those who don't.
New Rider May 2016
K9 Wee
booghotfoot is offline
post #8 of 17 Old 12-18-2018, 02:00 AM
Brockie's Avatar
I agree that the helmet mount gets rid of all the vibration and most of the wind noise but I kept finding that it was never recording when I wanted and so I solid mounted it and wired it in to start with power on - just like a dashcam. Mine overwrites the oldest clip first and I seem to get 10 hours or so on a 32GB card.
chicago likes this.
Brockie is offline
post #9 of 17 Old 12-19-2018, 11:24 PM Thread Starter
Ooh, thanks for all the info guys. I'm going to investigate some of these. For clarification, I have a 2018 V-strom 650. I mostly want this to record my death for my love ones later - not for hotdogging.
Brockie likes this.
FatCobra is offline
post #10 of 17 Old 05-04-2019, 09:20 PM Thread Starter
Hey all, just resurrecting this thread to tell you all I found a solution that worked pretty well. I got mirror extenders from AdventureTech that have a ram ball on the inside, and then added a 5.5" ram extender and put a go-pro ram ball mount on the camera. So the go pro sits like an antenna just to the inside of my right mirror. Got all this stuff off Amazon except the AdventureTech parts. Hope this helps anyone looking.
FatCobra is offline
Givi FB3112 GPS Mounting Bar rwbandler DL650A - 2017+ 18 05-06-2018 02:11 PM
Mounting a Polaroid action cam - Included mount vs. RAM Mount Impster Maintenance, Tech and Products. 0 04-02-2014 11:25 PM
