LED turn signals not blinking - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 06-26-2009, 12:26 AM Thread Starter
Mr.Metal's Avatar
Hey all,
I have the Buell turn signals on my 650 and I ordered some LED bulbs for them from superbrightleds.com. Specifically, I bought the 67x15 LED bulbs:
I got them today and... they don't seem to work right. If I put all 4 in, only 1 blinks, the rest don't light up. They're not bad, as I can switch them around and always only the one rear one blinks. The regular bulbs blink fine, albeit fast.
So, question is, why are 3 of the 4 LEDs not working? Do I need a load balancer because of the much smaller current draw? Why is that? Also, where exactly would I install that?
Feeling a little dumb...
2008 DL650 a.k.a. Road Warrior, member #16 of the Flat Black Club
2009 Aprilia Tuono 1000R a.k.a. Silver Thunder
Mr.Metal is offline
post #2 of 9 Old 06-26-2009, 04:44 AM
They either need load equalizers added or the flasher needs to be replaced with one that works with LEDs. I replaced my flasher with an FL-2 from http://autolumination.com/equalizers.htm following the instructions at http://vstrom.info/faq/index.php?sid...=76&artlang=en to conserve power for heated gear.
post #3 of 9 Old 06-26-2009, 05:35 AM
Heavy's Avatar
LEDs are polarity sensitive. Sounds to me like you have the + and - reversed on a few of those Buell signals.
Standard bulbs don't care.
"Unlike incandescent light bulbs, which illuminate regardless of the electrical polarity, LEDs will only light with correct electrical polarity."
http://en.wikipedia.org/wiki/Electri...larity_of_LEDs
Originally Posted by Mr.Metal View Post
...If I put all 4 in, only 1 blinks, the rest don't light up. They're not bad, as I can switch them around and always only the one rear one blinks...
DL1000K6
Heavy is offline
post #4 of 9 Old 06-26-2009, 05:47 AM
True. The flasher problem alone would not cause those symptoms. Good catch. The LED flasher is also polarity sensitive, unlike a thermal flasher would be.
post #5 of 9 Old 06-26-2009, 05:18 PM Thread Starter
Mr.Metal's Avatar
You guys are geniuses! I totally didn't think about the fact that LEDs were polarity sensitive, so much for my EE class from back in college
I will play with the wiring tonight and let you know how it goes. Luckily it's all posi-locks so it'll be super quick. I don't mind the faster blink rate, in fact I prefer it. With the LEDs, even the fast flashing will ensure 100% illumination with each flash. Way more noticeable in traffic than the "normal" slow flashing, in my opinion.
Thanks for the tips!
Mr.Metal is offline
post #6 of 9 Old 06-26-2009, 06:17 PM
Heavy's Avatar
You guys are geniuses! ...
aw... shucks... twernt nuttin...
...Thanks for the tips!
No need for the thanks. Just tell the other kids that I'm not always a prick. Besides, catching something that greywolf missed is plenty rewarding on its own.
DL1000K6
Heavy is offline
post #7 of 9 Old 06-28-2009, 08:18 PM Thread Starter
Mr.Metal's Avatar
Ok, here is my followup. Sure enough, 3 of the 4 turn signals were wired with the polarities reversed. It didn't matter for the regular bulbs, but the LEDs definitely cared. I spent about an hour fixing the problem and now all of the LEDs are installed and working.
In addition, I also installed the "extra bright" brake LEDs from the above-mentioned site (I think the same ones Greywolf mentioned in another thread). Boy, what a difference! I'm very happy with the results, so thank you for the tip to the quick fix.
I will be installing the new Admorelighting lite bar next weekend, so look for a post from me in the related thread once that's done.
I tell you guys, between the wired Givi trunk, the LED bulbs and soon the LED lite bar, the back of my Wee looks like a Christmas tree... a very fast Christmas tree
And for the record, Heavy is NOT a prick. You can quote me on that
Mr.Metal is offline
post #8 of 9 Old 06-28-2009, 09:51 PM
Gtown's Avatar
Here you go.
[SIZE="2"]"Life's tough, it's tougher if you're stupid."
[/SIZE]
FLAT BLACK #181
K8DL650
Gtown is offline
post #9 of 9 Old 06-29-2009, 10:18 AM
Heavy's Avatar
Originally Posted by Gtown View Post
Here you go.
WAHOO!!!
DL1000K6
Heavy is offline
