horn help please - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 06-18-2009, 10:47 PM Thread Starter
stevestrom's Avatar
horn help please
Alright, I installed (sort of) a Fiamm horn on my bike. I have a ground wire going from the battery to the horn and the power wire running to a relay. I have tied into the existing horn wires and run those to the relay as well.
Now according to everything that I have looked at this should make the new horn sound, but all I get is the old horn. I have checked and I have power at the relay from both the battery and the existing horn. I can make the relay 'click' when testing it, but still no horn.
Does the amperage of the relay matter? Do I have to wire the relay differently since the DL650 horn switch is on the ground wire?
Any help would be appreciated.
stevestrom is offline
post #2 of 5 Old 06-18-2009, 11:10 PM
You must have it wired wrong. The bottom wires go to 85 and 86. The top wires go to 87 and 30.
post #3 of 5 Old 06-19-2009, 08:10 PM Thread Starter
stevestrom's Avatar
Fixed it!
Thanks for the reply Greywolf.
I did have it wired correctly but my ground wire from the original horn was loose. Works like a charm now!
post #4 of 5 Old 06-19-2009, 08:39 PM
Well, if the wire was loose, it wasn't wired correctly.
post #5 of 5 Old 06-19-2009, 09:21 PM
Heavy's Avatar
Didn't start a fire so he wasn't too far off.
DL1000K6
Heavy is offline
