jumper cable connection - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
post #1 of 13 Old 04-30-2018, 06:51 PM Thread Starter
Greetings -- I am building a jumper cable. I have 12 awg wire an SAE connector that I will connect to 12 awg jumper cables via an SAE pigtail with the correct polarity. I will use a 20A fuse. QUESTION: Can I connect this jumper cable to my PC 8 fuse box or should I connect directly to the battery terminals? Regards, JL
JorgeLuis is offline
post #2 of 13 Old 04-30-2018, 07:32 PM
Rolex's Avatar
The cables should as short & as thick as possible for the best result.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #3 of 13 Old 04-30-2018, 08:24 PM
I recall reading somewhere that motorcycles should not be jump started. Anyone know if this is true?
Houstrom46* is offline
post #4 of 13 Old 04-30-2018, 08:31 PM
RustedRat's Avatar
i was talking with an old biker dude a while back and he said that if you are going to jump a bike it should be from another bike and nothing bigger. im not sure if this is true or not but i had some problems with my 2002 dyna and jumped it a few times and shortly after i was having a terrible charging problems even with a new battery so im not sure if it was the stator going out with it or if it was from improperly jumping it
JorgeLuis likes this.
"You can sleep next to a bike but you cant ride a house"-unknown
RustedRat is offline
post #5 of 13 Old 04-30-2018, 10:21 PM
[QUOTE=QUESTION: Can I connect this jumper cable to my PC 8 fuse box or should I connect directly to the battery terminals? Regards, JL[/QUOTE]
I would go direct to the battery unless you do not have that option. I think its advisable to keep the jumper lead as short as possible.
I jumped (with cables) my wife's (new to her) bike from her car tonight. The car has a 12 volt battery as does the bike. The car engine was not running at the time and it started the bike without damage to either vehicle.
JorgeLuis and MrF like this.
gdrew is online now
post #6 of 13 Old 04-30-2018, 10:55 PM
MrF
MrF's Avatar
I would not run that through your PC8 unless I had some proof that starting the bike draws less than 20A. Of course, blowing a 20A fuse would be a quick way to settle that. Your 12 AWG cable may handle it just fine, but think about the PC board in the PC8 that you're putting that current though.
Houstorm48, the issue with jumping a bike from a (modern) car has to do with differences in how the charging systems work. Bikes have a generator and the output is tied to engine speed. Generally, they output a little low at idle, and use a voltage regulator to "dump" excess voltage as waste heat as the RPMs rise. Cars have an alternator which changes the field current in the armature in order to keep a constant voltage output at varying RPM. If the car is trying to maintain a voltage higher than the bikes voltage regulator wants to maintain you'll get into a do-loop where the bikes voltage regulator is dumping voltage and the car's alternator
is trying to maintain it.. right up to the point where you fry the regulator.
I'm sure there are car/bike combos out there where the car outputs something less that the bikes reg tries to maintain. That's where you get the stories of "I've jumped off a running car before with no issues" when someone dismisses this concern. Since I don't carry a reference of car charging voltages around with me, I stick to the safe bet of jumping off a non-running car.
bikeflyer likes this.
2016 V-Strom 650
MrF is offline
post #7 of 13 Old 04-30-2018, 11:09 PM
Another vote for direct to battery. Intuitively I would say that starter motor could draw more than 20 amps. DL1000 starter motor is fused at 30A on the bike. As an alternative to jumper cables this seems like a good option:
https://www.amazon.com/GOOLOO-Starte...r+jump+starter
I'm not endorsing this particular one as I haven't tried it. They come in many sizes and ratings.
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
2013 V-Strom 650 - sold
G-Dub is offline
post #8 of 13 Old 04-30-2018, 11:14 PM
[QUOTE
is trying to maintain it.. right up to the point where you fry the regulator.[/QUOTE]
That's an excellent explanation MrF.
MrF likes this.
gdrew is online now
post #9 of 13 Old 05-01-2018, 08:22 AM Thread Starter
Greetings -- thank you for your very valuable & prompt feedback, including the highly technical stuff. per your recommendations, i will not connect the jumper cables to the PC 8 fuse box. instead, i will run the jumper cables directly to the battery with a 20A inline fuse. I will keep the 12 awg jumper cables short...approximately 8 feet if that sounds reasonable. If i connect the jumper cables to a car battery, the car engine will not be running. I'VE HEARD TELL: connect the jumper cables to a car battery for 5 minutes, disconnect the jumper cables, and then try to start the bike. QUESTION: in this example, will the bike battery get juice from the car battery if the car engine is not running or should the car engine be running? Regards, JL
post #10 of 13 Old 05-01-2018, 09:56 AM
Hi, guys. I got a set of jumper cables labeled 'Jackrabbit' from Quality chain corp.
the packaging says 10 ga. Comes in a nice zippered pouch.
It's about 10 ft in length and the wire is flexible so it folds up compactly.
Any 12volt battery can be used to jumper to a weak or flat battery. Just don't have the supply battery hooked to a charging system. Leave the car/truck engine off.
I had a car battery in the trunk of my Ural sidecar to replace the under seat battery on the bike.
Yes, your bike charging system can feed a bigger battery. What we have on the bike is limited space and the makers put in the most appropriate battery available to provide starting power..
Don't know you need to have a fuse when feeding a battery in a jumper situation. If your battery has an internal fault it may take more that 20 amps to make the system work. You may have to disconnect the bad battery and just run the bike on the external battery. That's why you do not have the car engine running as mentioned above.
Those handy jumper battery kits can start a bike but using one to continue to keep a bike running can apparently cause the unit to fail. It doesn't like to have the recharge through it's output.
And, yes it's best to have the connections directly on the battery terminals.
