Wiring Hella Optilux 1500 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 05-27-2009, 09:25 AM Thread Starter
mattyg's Avatar
Any electrical geniuses out there? I am not but I usually get by. I am setting up a pair of aux driving lights (Hella Optilux 1500s) activated by http://easternbeaver.com/Main/Elec__.../switches.html this Eastern Beaver switch (first one).
I have everything connected correctly I believe (well I guess if I did I wouldn't be writing this). The power & grounds are all routed back to my AP2 Fusepanel. The wiring diagram is not confusing but there are quite a few grounded connections, plus the EB switch has two leads vs. the stock 3 leads. The third lead on the stock switch is for activating the lights by the headlights. I want to operate these outside of the headlights so that shouldn't matter.
Just wondering if anyone else had any issues hooking these up? I don't have a multimeter so I have no quick way to tell what the problem is.
mattyg is offline
post #2 of 3 Old 05-28-2009, 09:43 AM Thread Starter
mattyg's Avatar
Well I got it fixed. Turns out the wiring schematic is incorrect if you use a switch other than the one that comes with the kit. For the price these are great lights. I guess I'll probably replace the bulbs with 35W units to conserve power though. :angel_23:
mattyg is offline
post #3 of 3 Old 06-01-2009, 09:14 PM
BDragon's Avatar
I've got 35w in my piia's.
Givi Windscreen, Madstads, E21 & E41 Panniers, E52 Top Case, Scorpion Stainless Exhaust, Famsa Tank Bag & Panniers, Symtec heated Grips w/ Grip Puppies, Pat Walsh Engine Guard / Skid Plate, OEM Handgaurds, OEM Center Stand, SWMotech Mirror Wideners, Metzler Tourance, 4" ABS Tube, AutoCom Pro 7, GIPro, Sargent Seat, BSS Fuse Block & Relay, Garmin Zumo 550, Stebel Air Horn, Aux Powerlets, Alaskan Leather, PIAA xtreme white, Superbrace, ToolTube, Kaoko Throttle Control, Highway Pegs, Risers (1" up 1" back) Sonic Springs, 1" raising links, PIAA 510 ATP, Touratech LED Tail Light, Touratech Zumo mount.
BDragon is offline
