My EB fusebox install - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 24 Old 05-14-2009, 09:52 AM Thread Starter
Here are a couple of pics of my PC-8 install for my hardwire GPS and aux outlets. Hadn't finished the mounting of bracket but will post after completion
ua99003 is offline
post #2 of 24 Old 05-14-2009, 01:26 PM
vstrompaul's Avatar
Thanks for the post and the pics.
That is my weekend project to install my latest EB farkles. PC8/tail light harness/headlight relay/OEM grip heater to fuse panel.
I like the idea of the sheet of aluminum as a backing mount. Is it fastened down to the plastic??
08 DL650A
The Amphibious Wee
07 CRF250X
Woods Weapon
vstrompaul is offline
post #3 of 24 Old 05-14-2009, 04:00 PM Thread Starter
Backing plate bent to confrom to tray and then velcoed in place ... I wanted to be able to remove
ua99003 is offline
post #4 of 24 Old 05-19-2009, 10:35 PM
I've got the same kit sitting next to me, haven't gotten around to installing yet. Your installation looks fantastic.
'07 Vstrom 650
jmo3373 is offline
post #5 of 24 Old 05-19-2009, 11:44 PM
vstrompaul's Avatar
The install was snap.
Here is my version. I followed your example ua99003
Just bent the sheet aluminum so it was elevated by 1/2 inch. Two wings of one inch with velcro but it also is a press fit.
08 DL650A
The Amphibious Wee
07 CRF250X
Woods Weapon
post #6 of 24 Old 05-20-2009, 08:32 AM Thread Starter
Looks good !!
Just curious .... why did you angle the PC8 ?
ua99003 is offline
post #7 of 24 Old 05-24-2009, 09:06 PM
I'm in the process of installing the same setup on my DL650AK8. I'm not the best with wiring, but I want to make sure i get this right. Is the rear brake the wire the orange/white one below the coolant reservoir (see attached pic)? I honestly dont know if this is a good test, but I disconnected it and turned it on to see if the brake would light up and it did..so I'm a bit unsure. Can anyone verify that that is the wire? and if its not, post a pic or describe the location of the correct one? I just want to make sure I do this right.
.navistrom - DL650AK8 :/: SuperBrace :/: H&B Crash Bars :/: H&B Centerstand :/: AdvMotoStuff Aluminum Engine Guard v1 :/: 36L CaribouCases
popnfresh is offline
post #8 of 24 Old 05-24-2009, 09:50 PM
The wire feeding the rear brake switch connector is orange/green, not orange/white. The picture at the Eastern Beaver site shows:
post #9 of 24 Old 05-24-2009, 11:10 PM
Thanks for mentioning the wire color. When I first saw the wire I thought it was solid orange; when in reality it was orange/green & white/black.
I've attached a better pic with a closeup of the wiring. I'm pretty positive it's that one as I couldnt really find anything else in that area with that color scheme.
post #10 of 24 Old 05-24-2009, 11:53 PM
That's it. The O/G is hot when the ignition is on. When the switch is closed, current is passed to the W/B wire.
