Eastern Beaver fuse block install - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 1 Old 05-14-2009, 03:06 AM Thread Starter
The Golden Monkey's Avatar
Finally got my new PC-8 fuse block from Eastern Beaver installed. Jim has excellent installation instructions and photos on his site. But since I have an ABS wee, there isn't room for the relay between the underseat tray and the battery, so I had to do things a little bit differently. Also the underseat tray is a little smaller than the non-ABS stroms.
I made a little bracket out of 1" aluminum bar stock to raise the PC-8 up a bit for better wire clearances.
I used industrial velcro to attach the box to the mount, and the mount to the underseat tray.
2010 Triumph Tiger 1050se
2009 DL650A - sold
2005 DL650 - dearly departed
The Golden Monkey is offline
