Admorelights for top or side panniers - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 13 Old 10-05-2017, 02:19 PM Thread Starter
thedrifter2010's Avatar
Just wondering if any one has used this product as I'm interested in the purchase of the top case lights for my Suzuki 48L top case.
Wondering if they are bright in sunlight ?
Bought some LED strip lighting from Wallmart and hooked them up behind my top case lens and they are really only visible at dusk or later.
I have noticed that the lenses in the Suzuki top case are rather opaque than clear
Any input would be helpful
Thanks
Tim "the drifter"
thedrifter2010 is offline
post #2 of 13 Old 10-05-2017, 04:19 PM
Sappuer's Avatar
I don?t know about your Suzi lens, but here they are on my Givi top box with clear lens and blue reflective tape.
I have thought about the side case lights. But haven?t pulled the trigger yet.
Also, I think the strips are adhesive, and flexible if you thought about mounting outside of the lens.
File Type: jpg A52174BE-5892-4455-A2C3-83FF598DA4D1_1507234600435.jpg (12.3 KB, 33 views)
Whatever you choose to ride, enjoy it and be open to new experiences.
Sappuer is offline
post #3 of 13 Old 10-05-2017, 08:30 PM
eagleeye's Avatar
If you are talking about admorelighting, I bought their LED kit for my givi 52L top box and it really lights it up
2009 Suzuki DL650
2005 Yamaha RSTD
2002 Triumph Bonneville
1980 Yamaha XS650 chopper
The Best Bike is the Bike You Like
eagleeye is offline
post #4 of 13 Old 10-05-2017, 09:50 PM Thread Starter
Exactly that.....thanks for the info.....the more lights in back the safer I feel....
Tim "the drifter"
post #5 of 13 Old 10-05-2017, 11:01 PM
Dry Heat?
Outbackwack's Avatar
Expensive but I've put them in my top cases and it makes a HUGE difference. Money well spent IMO.
Sent from my SM-N920V using Tapatalk
eagleeye likes this.
Get busy living, or get busy dying...
http://www.visitedstatesmap.com/image/AZCOCTILINIAKSKYMEMAMOMTNVNHNJNMNYOHPASDTXVTVAWVWY  sm.jpg
Outbackwack is offline
post #6 of 13 Old 10-06-2017, 12:40 AM
Vaseface's Avatar
I put the Admore light kit in my Shad top case. It worked great and really increased my visibility from the rear. I had a number of people comment to that effect.
Yes, it's expensive but if you are after more visibility, it does the trick.
Vaseface
Northern California
14 DL1000
Vaseface is offline
post #7 of 13 Old 10-06-2017, 10:49 AM
Stalky Tracker's Avatar
I added the Admore SMT lightbar above the license plate, either one really increases your visibility from the rear.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #8 of 13 Old 10-06-2017, 11:05 AM Thread Starter
Thanks for your feedback, emailed the Co. appears there is a direct plug in & go plug for an extra $25 may make it a little less complicated, would you happen to know where it may be located on the bike.
I looked at pics posted here in another section regarding a heated grip plug located in the upper left and one located near the bottom of the rad but both of these seem to far away from the rear of the bike.
Is there a direct plug and play located under the seat somewhere ?
Thanks again for all your input
Tim "the drifter"
post #9 of 13 Old 10-06-2017, 11:06 AM Thread Starter
Thanks for the input ....seems the way to go for me
Thanks
Tim "the drifter"
post #10 of 13 Old 10-06-2017, 11:27 AM
You can tap into the rear lights on the left side rear (white plug in pic), need to remove the rear fender. Eastern Beaver make a Brake/Tail/Signal Adapter to tap into it. I don't know if Admore does too.
1974 Suzuki TM-250
1965 Suzuki 80
