installing a power outlet - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 04-20-2009, 08:12 AM Thread Starter
What are the pros and cons of using the BMW type power outlet? I can not decide if I should install the cigarette type outlet or the powerlet. On the stroms there is supposed to be a wire to hook into that is there for heated grips. Does someone have a pic of what this looks like so I do not slice into the wrong thing?
mike1952 is offline
post #2 of 14 Old 04-20-2009, 08:35 AM
K1W1's Avatar
The BMW style outlets are more secure and reliable but it's unlikely that you will find many off the shelf products that have the plugs for them. Most 12v auto products have cigarette socket plugs. I have a BMW Powerlet socket on the left side of the fairing and a cigarette cable adapter in case I need it which gives me both options.
The Powerlet kits wire back to the battery or to an accessory fuse box that is usually mounted under the seat. Mine simply goes to the battery which means it's live all the time so I'm just careful not to leave anything in it when the ignition is turned off.
On the Wee the heated grip wire is behind the radiator near the fan. it's the only plug there that does not connect to anything and it's a real pain to get to.
K1W1 is offline
post #3 of 14 Old 04-20-2009, 08:42 AM
Dread7's Avatar
Outlet
If you don't have things that specifically plug into the powerlet, like a heated vest etc..., then I would get the cigarette type outlet but it really is what YOU have to plug in. The heated grip plug you are looking for is under the gas tank. I would still just run your outlet straight to your battery with an inline fuse or better yet put in a fuse box for future farkles. That way you know how much power you can use there. Some of the chargers, GPS or whatever you plan to run there may be too much for that heated grip outlet.
Formerly clovett but changed to my gaming name
2004 DL650 1998 DR650 1994 CB1000 1992 DR350
2004 Z400 1965 Norton 650 1984 Honda XL200
1975 Suzuki RM125 1972 Yamaha 100 enduro
1971 Honda CT90 1968 Honda Z50A
Dread7 is offline
post #4 of 14 Old 04-20-2009, 11:10 AM
The OEM connector has the capacity to run heated grips. GPS units and other electronic devices take a lot less power. An air compressor, for example, is a different story.
post #5 of 14 Old 04-20-2009, 03:31 PM
MacGyver's Avatar
I started cheap and easy with my KLR electronics and went with cigar sockets. They work, but they don't lock in place as Powerlet products do. When I wire up the V-Strom, it will be with Powerlet outlets and I will carry an adaptor as K1W1 mentioned. The other advantage of Powerlets, they are much smaller.
The negative side of this is endevour is I will have to re-wire my existing cigar adapters to Powerlet plugs, but I enjoy eletronics so that is not a big deal.
Hope that helps,
Tim
TMEGMOTT (too much extra gear most of the time)
2011 V-Strom 650ABS - Back In The Saddle Again!
MacGyver is offline
post #6 of 14 Old 04-20-2009, 04:23 PM
Be careful. Some electronics such as GPS units have a 12V-5V reducer built into the cigar lighter plug.
post #7 of 14 Old 04-27-2009, 08:18 PM
JPryce's Avatar
I just went through the same thing. Ended up going with Powerlet cigarette lighter with a weather cap.
Looking at the bike, my question is where the heck to mount it. I had considered mounting it inside one of my Zegas so I could charge the phone, computer, etc on trips, but the thought of drilling a large hole in one of those babies made me a little sick..
Not much real-estate to work with.
2012 Super Tenere
2006 CRF50 with big-boy mods. :biggrin:
1973 RD350
JPryce is offline
post #8 of 14 Old 04-28-2009, 09:44 AM
Dread7's Avatar
Mounting
I got the one from Eastern Beaver with a weather cap. It's a round cylinder and just fits in the wiring loom on the fork that the clutch cable slips through. I used the nut on the bottom and it's secure. Dunno if yours is the right size but mine fits with plenty of slack for the clutch cable to work in. Here is a shot, I could have drilled a hole but why?
Dread7 is offline
post #9 of 14 Old 04-28-2009, 07:41 PM
JPryce's Avatar
Now that^^, my man, is a great idea!
2012 Super Tenere
1973 RD350
JPryce is offline
post #10 of 14 Old 04-29-2009, 06:11 AM
Stromtrooper.com Sponsor
Jim Davis's Avatar
Ya, nice one. Can I use that photo on my site?
Jim Davis, Owner, Eastern Beaver Company:
http://easternbeaver.com/ - Motorcycle Electrics: 2007 DL1000 with 16/43 gearing, Superbrace, Tokico 4 Pot fronts, BackoffXP, H4 Dual Relay Kit, PC-8 Fusepanel, 2 Powerlet Sockets, Suzuki Centerstand - 1988 Africa Twin 650, 1990 VFR 750.
Jim Davis is offline
