Wiring a power outlet to my v-strom 650 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By ScottTheFalcon
post #1 of 7 Old 08-25-2017, 05:01 PM Thread Starter
I have a 2013 v-strom 650 and looking for advise for wiring a powerlet socket kit to my bike? I would like to limit the risk of draining my battery if devises are left plugged in, but would like to keep the install and accessories as simple as possible. I have little experience with bike wiring and have not been able to find some simple instruction on the forums or youtube.
pt
2013 DL 650
ptilts is offline
post #2 of 7 Old 08-25-2017, 06:01 PM
What do you intend to plug into the outlet? It's easy to find enough power for a GPS or phone that is switched with the ignition but more complex to run a high load device like an air compressor.
post #3 of 7 Old 08-25-2017, 06:19 PM Thread Starter
Just a GPS and a phone, low power needs.
pt
2013 DL 650
ptilts is offline
post #4 of 7 Old 08-25-2017, 06:29 PM
Then you can use the aux connector in the right side of the fairing or the heated grip connector behind the radiator.
https://www.stromtrooper.com/dl650a-2...-location.html
https://www.youtube.com/watch?v=RYvt-vO0kJo
post #5 of 7 Old 08-25-2017, 07:43 PM
Using a switched outlet will allow you to run big power to an outlet though a relay.
Even a GPS will drain the battery if left on long enough. How do I know that?
I ran my 12v outlet with a fuse but direct to the battery. So I have to remember to shut stuff off.
Do it right and enjoy the benefits!
post #6 of 7 Old 08-25-2017, 08:24 PM
ScottTheFalcon's Avatar
I've wired a switch in (red LED toggle switch from Adventure Tech) so that I can make my ACC outlet (right, below) direct connect to the battery, or only while the engine key switch is on. Obviously include a fuse in the circuit if you do this. Normally pretty fail-safe. Switch it over to continuously power accessories or plug in a battery tender if need be.
The green switch powers an accessory SAE connector for compressors or the like.
Stalky Tracker likes this.
ScottTheFalcon is offline
post #7 of 7 Old 09-16-2017, 07:17 PM Thread Starter
Thanks for the advice
pt
2013 DL 650
ptilts is offline
