Switch, is this good? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 14 Old 07-17-2017, 02:56 PM Thread Starter
Null 13's Avatar
I received this from china, but was told by someone it might not be good because it's not sealed.
Opinions? Suggestions? Does Suzuki offer a switch i could buy that would look better?
Switch
________
2014 VStrom 1000 Adv SE, because army bikes are more adv
Null 13 is offline
post #2 of 14 Old 07-17-2017, 03:27 PM
None of the stock switches on your bike are sealed either.
vegashotwheeler and Null 13 like this.
post #3 of 14 Old 07-17-2017, 07:53 PM Thread Starter
Null 13's Avatar
Cool thanks!
________
Null 13 is offline
post #4 of 14 Old 07-17-2017, 08:36 PM
vegashotwheeler's Avatar
Send a message via AIM to vegashotwheeler
I like it!
Let us know how well it works,
Mike
Null 13 likes this.
2007 Blue DL650 V-Strom - running out of farkle's to do so bought the VEE
2006 SILVER DL1000 - Running out of Farkles also!!!
2017 EX300 Kawasaki Ninja
Las Vegas, NV
vegashotwheeler is offline
post #5 of 14 Old 07-17-2017, 10:49 PM
Whatchu gonna do with it?
notacop is online now
post #6 of 14 Old 07-19-2017, 04:30 PM Thread Starter
Null 13's Avatar
Was gonna ask the dealership to install my new lights... but at 200$ for install plus 50$ for the no-name brackets, no thanks.
I'll just take my time and order some 10-15$ ebay brackets. Ideally, i'd like to find a plug to tap into the front aux port (the one used for heating grips) for power.
________
Null 13 is offline
post #7 of 14 Old 07-19-2017, 06:08 PM
blaustrom's Avatar
You should find that connector at eastern beaver.
blaustrom is online now
post #8 of 14 Old 07-19-2017, 07:35 PM
Grimmer's Avatar
Assuming they are low current LED lights and that you are running a Vee2, you can use the white lead from the horn just under the beak. Build a "Y" splitter with those crimp (or solder) flat blade quick connect terminals. Then you can plug one end back onto the horn and the other to whatever you please. Those crimp terminals are available in water resistant styles or you can heat shrink over them once they are connected.
Added bonus is that the white horn lead is switched +12V to the key "on" position only and won't be powered when you set the key to "P"ark.
Grimmer is offline
post #9 of 14 Old 07-19-2017, 08:20 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
We have our new wiring harnesses in stock. Three wires connect to the bike. Red to batery postive, black to battery negative, white to a switched source (e.g., tail light positive).
Suzuki Auxiliary LED Lighting - AdventureTech, LLC.
richlandrick is offline
post #10 of 14 Old 07-19-2017, 08:32 PM Thread Starter
Null 13's Avatar
Wow, never thought about doing it that way
Here are the specs the the lights:
Voltage: 10V-30V
Power: 18W
Lumens: 1800LM
________
Null 13 is offline
