Eastern Beaver Heated Grips Adaptor - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 07-09-2017, 03:22 AM Thread Starter
Hi all, I've searched the forum for an answer however after going through pages of posts, no answer.
I've ordered the heated grip adaptor from EB to connect my Oxford heat grips to the on bike hated grip power source (you know the one near the radiator).
Question, the EB adaptor has a connection on one end and two open wires the other. Does the connection on one end plug into the connector on the bike? If so what type of connection do I need on the other end to plug into the heated grips power in?
Thanks.
Parso is offline
post #2 of 2 Old 07-09-2017, 07:28 AM
ScottTheFalcon's Avatar
The Oxford heated grips I've seen have a controller, and two wires with ring terminals that go to your battery. If you really want to use the EB connector:
- Cut off the ring connectors on the Oxford heated grip cable, that would normally go to the battery
- Join red to red, black to black, on the EB cable free wires end
- EB cable with the modular connector goes to the heated grip connector near the radiator.
If your grips come with battery leads and a controller, it's easier and cleaner to just go to the battery.
What model are your Oxford heated grips? They make a few...
ScottTheFalcon is offline
