Hardwiring Nuvi 265WT - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 03-05-2009, 09:06 PM Thread Starter
KRS
Okay, I've hardwired a Garmin eTrex Legend before directly to 12v (using the voltage reducing circuitry).
I now have a Nuvi 265WT. It uses a USB mini-plug.
Can I just cut any old USB mini-plug cable I have lying around and make up a 12v charging cable? Any idea which wires are the + and - ?
Thanks all,
KRS
Current Bikes: 2007 Suzuki V-Strom DL1000; 2004 Manco Streaker (woo hoo!)
Past Bikes: 2000 Kawasaki KLR650; 1992 Kawasaki Vulcan; 1986 Yamaha 650RJ The "Real" Seca
Current Farkles: Bigger windscreen with adjustable mounts; GPS/Radar shelf; Side guards; Fender extender; Gel seat; Rear Box; Relay with switched power for power outlet and GPS; Hardwired GPS
KRS is offline
post #2 of 4 Old 03-05-2009, 09:13 PM
The bike is 12V and the GPS needs 5V. You need the cable for plugging into a vehicle that includes a voltage regulator. If you are using the old power supply, re for + and black for - is typical. Ribbed v. unribbed has too much variation. Test with a meter.
post #3 of 4 Old 03-12-2009, 10:10 AM
toma nova
I bought the Garmin 12v wiring kit to hardwire my Nuvi250W. It has bare leads, a small "converter" box and the mini-USB plug. It's all about 6 feet long, plenty of length from the fuse box to my handlebars. Maybe cost $30 or so.
I've got limited access to electrical things here (no Radio Shack) so there may be a cheaper alternative, but the Garmin kit does indeed work!
I had trouble with the plug and the RAM mount so I dremeled some of the back of the mount away and epoxied a strip of elastic on to help hold the plug in. No vibration issues now on gravel roads.
Tom
post #4 of 4 Old 03-13-2009, 04:05 PM
Boondocker's Avatar
Funny you should mention the RAM mount. I recently picked up a Nuvi 260 and bought a RAM mount straight away because RAM mount stuff is usually awesome. So I was surprised and a little disapointed that the plug wouldn't clear the holder. Dremel to the rescue as usual! Since I have a cig socket, I probably won't hardwire. I haven't used it on the bike yet, so I'm hoping it's glove-friendly. The Nuvi line isn't rated for moisture or vibration (read motorcycle use). I'll use it anyway.
Uncommonly Sensible
'04 DL650 - Blue, 57,000 miles, well personalized, gone but loved
'08 WR250R - Goes anywhere
2012 Yamaha Super Ténéré - makes the DL redundant
Boondocker is offline
