My K4 Gets a Voltage Monitor - Very Cool! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 03-09-2017, 09:44 AM Thread Starter
Thumbs up My K4 Gets a Voltage Monitor - Very Cool!
Having to replace my battery recently due to failure to keep properly charged, I decided to install a SparkBright voltage monitor. I chose this one due to it's simplicity and extremely small size. It is reasonable priced and was shipped very quickly from the U.K.
Pic shows a steady Orange which means battery is OK with ignition off.
Their website has all the info....
Eclipse Battery Voltage Monitor | SparkBright
Too Fast to be Last!
DL1000 Pilot is offline
post #2 of 9 Old 03-09-2017, 08:38 PM
Hey DL1000, can I ask which model of SparkBright voltage monitors you decided to pick from the following list and why? Might help me to decide which one to get.
Monsoon10 -
Monsoon8 -
Monsoon5 -
Eclipse10 -
Eclipse8 -
Eclipse5 -
Thanks,
gdrew
gdrew is online now
post #3 of 9 Old 03-09-2017, 10:54 PM
Monsoon10 -
Monsoon8 -
Monsoon5 -
Eclipse10 -
Eclipse8 -
Eclipse5 -
Thanks,
gdrew
If I may butt in...I got the Eclipse 8. The Eclipse is the self-dimming one and I wanted that feature. If you connect it directly to the battery, when you cover the bike it dims and the current draw is very low, less than 2mA. As far as the size, I wanted a larger one that would show up better, and someone at the company told me the 8 was about the same brightness as the 10 and required a smaller mounting hole.
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
2013 V-Strom 650 - sold
G-Dub is offline
post #4 of 9 Old 03-09-2017, 10:57 PM
THis is great. Did you wire it directly to the battery?
2011 DL650
Copernicus is offline
post #5 of 9 Old 03-09-2017, 11:14 PM
I have one to put on the Gixxus and haven't installed it yet, but probably will wire to the battery. I was going to ask Pilot this question. I think it would be fine, especially if it's dark most of the time (covered or in a shed), and if it isn't ridden for a couple weeks probably should put it on a tender (which I do anyway). To put the power consumption in perspective, a typical AA alkaline battery can supply 2mA of current for about two months continuously. (Edit - of course, you would need 8 AA batteries to power the Sparkbright.)
If wiring to the battery was a concern and you didn't want to install a relay just for the light, you could always put a small toggle switch inline next to the light so you could turn it off if not ridden for long periods.
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
G-Dub is offline
post #6 of 9 Old 03-09-2017, 11:14 PM
Yes, I was thinking the Eclipse 8 to for the reasons you mentioned. Did you get them to extend the wires for you or were they long enough for your install?
gdrew is online now
post #7 of 9 Old 03-09-2017, 11:33 PM
I have not installed yet, but it just has stock length wires, 24" long, looks to be only 24 gauge individual wires, easy to extend. I'll either put the wires in a sleeve or wrap with tape for protection and connect to the battery through a small fuse of 1 amp or less.
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
G-Dub is offline
post #8 of 9 Old 03-09-2017, 11:50 PM
I'll likely do the same, thanks G-Dub.
gdrew is online now
post #9 of 9 Old 03-10-2017, 02:13 PM Thread Starter
I installed the Eclipse 5 on my K4 and....
it's wired into the battery leads to the E/B headlight relays. Find it to be just as advertised and works great!
