normal ON relay? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 01-19-2009, 01:49 PM Thread Starter
normal ON relay?
Let's say you have a standard 12V relay, such as is used with lights, horns and such. In it's normal use it is a normal OFF, the contacts only activated when power is applied.
What if it was installed in a normal ON arrangement? Would the relay burn up fairly quickly?
"They will find the streets are guarded by United States Marines!"
2007 Vee with two round black things and a neat thingy on the right that makes it go faster!
cwadej is offline
post #2 of 6 Old 01-19-2009, 02:04 PM
What are you trying to accomplish? Relays with normally closed contacts are available. That may be what you want. When the relay is not powered, one pair of contacts pass electricity and the relay uses no power itself.
post #3 of 6 Old 01-19-2009, 02:29 PM Thread Starter
I'm going to run the brake, tail, turns (same fuse) through a small rocker switch. Switch is only 6 amp, fuse is 15. I want to be able to turn off the tail and headlights (different switches of course) when I'm off road.
I actually had one in the garage. 5 pin. center pin is for normally on.
Thanks for the help. Glad I looked at what I had.
cwadej is offline
post #4 of 6 Old 01-19-2009, 02:33 PM
You want a five terminal SPDT relay. There are a bunch of different models. See http://www.the12volt.com/relays/relays.asp See some examples at http://www.amazon.com/VDC-Automotive.../dp/B0002KR9GG
post #5 of 6 Old 01-20-2009, 06:04 AM
msi1259's Avatar
Because the VStrom has a shunt regulator (shorts the output of the stator to regulate voltage), running with less load can be harder on the stator and regulator then heavy loads. A permanent magnet alternator produces power whether that power is being used or not, so any energy not used is converted to heat in the stator and regulator.
You need the lights out to run from the cops / land use enforcement?
DL1000K5
msi1259 is offline
post #6 of 6 Old 01-20-2009, 12:58 PM Thread Starter
Can you even run from a cop on a Strom? Not that I would. End my military career, not to mention loosing my clearance, which is useful in other ways. No land to enforce. I just like to have gadgets.
cwadej is offline
